It is currently Tue Jun 16, 2026 10:00 am
 Post subject: radiator size
PostPosted: Sun Jan 17, 2010 2:07 pm
I dont have my OFM or by my car but need to order a radiator, dont know the length or height of it. can Someone look it up or inform me.
going to get a afco radiator.
1963 Valiant
225 pw steer
auto tran.
will get a separate trani cooler and will go electric fan or should I just run the stock fan?
thank you
 Post subject: size
PostPosted: Sun Jan 17, 2010 2:38 pm
Just went out and measured my stock 63 Valiant rad
Core size 18 3/4" wide 17" high 2 core.
Overall hight 21 3/4" 22 1/4" to top of cap
Mounting bolt flange to flange wide 21 3/8" High 12"
Let us know what you ordered, part# and cost as reference.
The rest is up to you as far as fan. I used a 16" 5 blade SS flex to replace the iron 4 blade.
PostPosted: Sun Jan 17, 2010 3:45 pm
Don't know who Afco are or what their radiators look like, but see here.
 Post subject: quote
PostPosted: Sun Jan 17, 2010 9:12 pm
http://www.summitracing.com/checkout/cart.aspx
check this....haven't paid for yet.
 Post subject: thanxs
PostPosted: Sun Jan 17, 2010 9:13 pm
Thank you for your time.
 Post subject: Re: quote
PostPosted: Sun Jan 17, 2010 9:44 pm
Doesn't work that way. That URL only works for you, not for us, and then only until you close your browser.
PostPosted: Mon Jan 18, 2010 7:21 am
http://www.summitracing.com/parts/BCI-10038/
 Post subject: Rad
PostPosted: Mon Jan 18, 2010 7:58 am
Check you part#,,, The one you show has the outlet on the wrong side.
PostPosted: Mon Jan 18, 2010 8:07 am
Way too wide (and probably too thick) for an installation in your '63 Valiant without substantial hacking. Why not get a radiator of the correct size, shape, and bracket configuration? It's not much more costly than this "universal" item.
PostPosted: Mon Jan 18, 2010 8:37 am
There is an Afco size that fits nicely. Dart 270 has had one in his 64 for years......
Id search Afco rad on here........
 Post subject: found this one.....
PostPosted: Fri Jan 22, 2010 7:09 am
this is the most likely candidate without getting the Guy to make me one. Which will probably be the best bet.
Even though this is the closest I've come to an original replacement.
http://www.summitracing.com/parts/PLI-433354/
PostPosted: Fri Jan 22, 2010 6:50 pm
Proliance's stuff for our cars is of pathetic quality any more. You should see the halfazzed junk they foist off as a heater core for a '73+ A-body with A/C. None for me, thanks, I'm driving.
 Post subject: thank you Dan
PostPosted: Fri Jan 29, 2010 8:43 am
After all said and done, I could/would have saved dayz of blunder and just listened to you Dan. I have ordered a radiator from your guy. Will rest peacefully now.
again thank you. :lol:
 Post subject: Re: thank you Dan
PostPosted: Fri Jan 29, 2010 6:50 pm
I'm Just wondering how much did that cost?
64 dart GT /225
...........____ .
...._n_.[____].
.....L\....\......
.......\____\....
PostPosted: Fri Jan 29, 2010 8:28 pm
Proliance... didnt that used to be Modine? (which was regarded as the best)
