It is currently Wed Dec 31, 2025 5:03 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Mon Jan 18, 2010 6:17 am
Thanks again everyone. I'm ordering parts today and will let you know what I decide.
I had trouble running these Weber 40s on Project V with an unregulated stock pump at higher RPM. Must have been sinking the floats.
I am leaning towards two of the little Mr. Gasket pumps in parallel that Dick posted above.
PostPosted: Sat Mar 27, 2010 4:09 pm
Car Model: Toad Wagon
OK, an update and a warning.
I've already notified Lou. My apologies Lou.
I recently bought six more of the Mr. Gasket 3 lb pumps (the 42S that I've had on the HAMBster for awhile) for our float (Tournament's rather anal about redundancy :lol: ). They each put out 7 lbs. I called Mr. Gasket's help line and was informed that's what they are now. They run at 3 lbs only when free-flowing and need a regulator to achieve it when hooked to a system.
I bespoke my displeasure with their ad that makes no mention of that fact.
They hung up on me.
I'll be reiterating it in a formal letter.
I'm having to order some regulators, and will get an extra for such time as the HAMBster's pump fails and needs updating.
I regret and rescind my advice to use these pumps for low pressure systems, they're no longer valid for that application.
Also, please, if you're stuck with this situation, do NOT buy the cheap "knob" style regulators. Get the fully enclosed, screw adjust sort, they're leagues safer.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Sat Mar 27, 2010 5:36 pm
I run the carter electric pump on my duster,alot cheaper than holley and works real nice.I have never used webbers,only the hyperpac and edelbrock carbs.
PostPosted: Sat Mar 27, 2010 8:22 pm
Robert West,
3lb (3.5lb max as I strictly run weber on mine) out of these carter electric pump and quiet and hum nicely? (rotory pump do this).
Cheers, Wizard
PostPosted: Sun Mar 28, 2010 4:23 am
Thanks for the detailed info, old6... I guess I won't pull these back off and send back, but just add a regulator. Major bummer. Yay to misinformation and bad treatment from big companies!!
I looked at the Carter pump too, and may use that at some point. Believe they are 6 psi rated.
