It is currently Fri May 15, 2026 12:46 pm
 Post subject: Engine ID
PostPosted: Tue Jan 19, 2010 4:26 am
Can you help me identify what year this engine is. I thought I seen a chart somewhere but couldn't find it. Hopefully it is a forged crank engine.
Numbers stamped on top edge of block are: 9 225R 1 3
Thanks, Rick
PostPosted: Tue Jan 19, 2010 7:44 am
Rick
Articles section. Also quick glance at the water pump Area of the block. Ridges are different on the back for cast and forged.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: Casting number
PostPosted: Tue Jan 19, 2010 12:41 pm
Yes Frank, I looked there already. But I only see 3 casting numbers listed under "blocks" and none of mine are similar.
My block is a 5 freeze plug block, Drivers side block has- F 530-6 3038
Passenger side has- 6 (clock point at #8) 23
I did not see any casting numbers similar to those listed on that chart.
I'll go look again, but I thought the stamping in the top of the block identified years?
Thanks, Rick
PostPosted: Tue Jan 19, 2010 12:48 pm
Rick,
If you don't have tall/large casting numbers on the block you've likely got a cast crank engine. I think the 9 is probably 1979.
 Post subject: Thanks
PostPosted: Tue Jan 19, 2010 12:51 pm
Your probably right Josh. I don't see any large casting numbers. And by the chart it has a 79-80 cylinder head casting.
Thanks You, Rick
PostPosted: Tue Jan 19, 2010 1:00 pm
9 225R 1 3
9: 1979 model year
225: Engine displacement
R: Passenger car application
1 3: January 3, 1979
PostPosted: Tue Jan 19, 2010 5:03 pm
since you're on the subject of engine ID...
I have a slant that I have identified as a 225 by the casting numbers (2463430) that was castin 1964, but oddly has a upside down 170 cast into the block as well. Just seems odd
1964 Dodge A100 Truck
PostPosted: Tue Jan 19, 2010 6:13 pm
Thanks Dan.
Rick
PostPosted: Wed Jan 20, 2010 7:40 am
No problem with cast crank motors. I just built one as a new HiPo engine for the '64 Dart. Rodney Hargis won most of his trophies running high 12s with his cast cranker that lasted several thousand passes (10,000?)and at least 5-7 yrs in his Lancer. 1st 225 motor in the 10s was a cast crank.
1979 is in the range of years that Mike Jeffrey likes best for porting an all out head too.
