It is currently Sun May 17, 2026 9:12 pm
 Post subject: wont idle in gear
PostPosted: Tue Jan 19, 2010 3:36 pm
I have a 1978 plymouth volare with a fresh rebuild /6. I am having problems with it running ruff and idle. Here is what i have i have done 81 block out of pickup 78 head off my motor . aftermarket comp cam. dies in gear very ruff idle new exshate manifold second set of spark plugs valve adjustment checked 3 times will pop back though carb if i rev engine as it is dieing any ideals revs up fine as long as motor is not trying to die
PostPosted: Tue Jan 19, 2010 6:00 pm
Popping back through the carb sounds like it could be a timing issue.
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
PostPosted: Tue Jan 19, 2010 6:26 pm
Car Model: '64 Valiant Convertible
I vote for TIMING/IGNITION. What type of ignition? Points? Electronic? Vacuum advance?
If it won't idle, tough to check for a vacuum reading...
PostPosted: Tue Jan 19, 2010 6:29 pm
How about firing order? Firing on all 6? Just trying to eliminate the easy stuff.
PostPosted: Tue Jan 19, 2010 7:40 pm
Your '78 Volare should have electronic ignition.
I agree with the others who have said that it sounds like a timing/ignition issue.
Welcome to the site!
'78 Volare 225
'67 Charger 318
PostPosted: Tue Jan 19, 2010 8:06 pm
6 Pack Dart
Sure all vacuum lines are hooked up??
 Post subject: what i have done
PostPosted: Wed Jan 20, 2010 8:31 am
yes i have checked all vac lines on motor and i have pulled all spark plugs and replaced them with new . also checked tdc on compresson stroke disturbutur is dead on it is electronic but sounds to me to be skipping a beat here and there . will idle in park but after a few min dies out but wont idle at all in gear just dies the only thing i have not done is rebuild the carb which was new 3 years ago but sat for a year while motor was worked over can adjust mixture screws in and will kill motor so dont think carb is clogged tempted to slap a points disturbutur on it and go old school see how that works
PostPosted: Wed Jan 20, 2010 4:52 pm
well pulling the car out of garage to tinker with the timing some more she died half way out of garage and now is not firing at all fire coming out of coil wire but nothing out of disturbutor so now more problems have spare disturbutor so will try that my next weekend
