It is currently Thu May 21, 2026 9:05 am
Post new topic  Reply to topic  [ 40 posts ]  Go to page Previous 1 2 3
PostPosted: Wed Jan 20, 2010 3:59 am
This view of "inside the SL6 head" helps me visualize how the upper and lower water jacket cores were done (by the factory) and how they could be layed-out in an after-market head.
So are you saying that your working to develop an aftermarket head?
PostPosted: Wed Jan 20, 2010 7:36 am
Our local high school (165 students) offers an Art Metal 12 class that involves casting aluminum. They use a propane setup.
My daughter (she is now a ticketed welder) loved the process and was allowed to pour whenver she had a mould.
Most students make a shifter nob , ashh tray , death metal shrine, pipe stand or a mess. Kate got into fantasy figurines, four pound dragons etc. Tim:you should drop by sometime so Kate can take you up to the school....
Anyone interested in casting art should out Fredrick Remington.
I was thinking it would be fun to port Dougs 2 piece head .....deck the two pieces for reassembly ......glue and clamp. I bet porting is more fun in a 2 piece head.
Then you try it in plywood. Glue and clamp...
Keep posting pictures Doug.
PostPosted: Wed Jan 20, 2010 9:09 am
I have had the plans / blueprints for an aftermarket SL6 cylinder head for over 15 years now.
I have "run the numbers" twice... got quotes for castings, machining, (including programming, holding fixtures, cutters & taps) and the final "press work". (installation for 12 guides and 12 valve seats)
When all is said and done, we always find the same answer, "too expensive".
So... I always know what "next steps" are needed for the project and time can be your friend.
This year, I was able to move a few steps forward... finding someone with a big saw was one of those forward steps.
There are still many more to go.
PostPosted: Wed Jan 20, 2010 9:43 am
Now that's an interesting print. What is #3698446, and who is BW?
PostPosted: Wed Jan 20, 2010 10:55 am
Car Model: 1964 Valiant
You can do a prototype head from steel weldments.
Years ago Crosley brazed the block for its tiny Hot Shot
motors. http://crosleyautoclub.com/Mighty_Tin.html
There were warranty and corrosion problems, they went
to an iron casting, but the thing did work. With the
improved welding of today a welded prototype can work
for a one off. With CNC you could fabricate and weld up
a few test heads.
PostPosted: Wed Jan 20, 2010 2:25 pm
Unless you have a better Idea, I think it might be:
"Bill Weertman, the Chrysler chief engineer who worked with the Slant 6 development program from 1958 to 1987 ."( c & p from the Articles section.)
Anyone got any better idea/theory ?
cheers,CRM
:D
PostPosted: Wed Jan 20, 2010 2:43 pm
#3698446,........part # for the alloy head....an online check says there are 5 in Edmonton...but only 3 are the big valve version. :wink:
PostPosted: Thu Jan 21, 2010 3:31 am
If you ever get to the point where you find it's possible to be done, you can sign me up for one! :D
PostPosted: Thu Jan 21, 2010 8:26 am
I thought about "BW" meaning "Bill Weertman", but I'm pretty sure he signed most of his work "Willem", not "Bill".
PostPosted: Thu Jan 21, 2010 4:31 pm
Poser
Thanks Doc! Baby steps are still steps in the right direction!
Users browsing this forum: mr.norm and 23 guests
