It is currently Fri Jun 05, 2026 11:04 pm
 Post subject: Mallory Distributor
PostPosted: Mon Jan 25, 2010 8:07 am
Has anyone put one of these Mallory 4562201 in use and if so what are your thoughts? I am building a 225 milled head, decked block, 9.5:1 Compression a lot of porting, big valves and a four barrel. I am looking for the best ignition possible. Thank you in advance
Raymond Flynn
Registered Six Offender!!!!
PostPosted: Mon Jan 25, 2010 8:41 am
The factory electronic distributor with appropriate advance curves is every bit as good as the Mallory distributor. Teamed with an HEI module and coil you'll have all the ignition you need on 95+% of the slants out there.
PostPosted: Mon Jan 25, 2010 10:56 am
+1 for HEI and Mopar EI distributor.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Jan 25, 2010 6:33 pm
Site Admin
I run a Mallory. There is no provision Vacuum advance. Mine is infinitely adjustable 0-28° Mechanical, and with the spring kit the curve is very adjustable.
This part is useful for the application I use it for; Drag Racing. For a street car, you may find it to be a limiter.
As far as economy is concerned, it costs me a mpg from my Mopar EI Dizzy. Maybe.
Parts for the Mallory are more expensive than for the Mopar.
Do I like it for my Drag Car? Yep. Would I put one on my street car? Maybe. For a Daily Driver, no.
:D
CJ
PostPosted: Tue Jan 26, 2010 3:07 pm
I will be using this motor strictly for drag racing I do not know if that would make a diffrence on your post Frank and Josh. I do thank you guys for the info.
Raymond Flynn
PostPosted: Fri Jan 29, 2010 5:45 pm
I'll be running a mallory in my street/strip car. What gets me is the mounting to the block. How does that work?
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
Users browsing this forum: Bing [Bot] and 6 guests
