It is currently Sat Jun 13, 2026 5:42 am
PostPosted: Tue Jan 26, 2010 12:47 pm
Just started cleaning my 2nd slant head ('76 peanut head) and noticed that the head bolt mounting pads on pushrod side are all chipped on the left side (when viewed from the pushrod side((left side of lead))) heres the pics
and the ID mounting pad
I will be using head studs, and just need to know 2 things
1.) What would cause this ?
2.) Is the head salvagable/useable with head studs ?
-Mike[/img]
 Post subject: chipped boss
PostPosted: Tue Jan 26, 2010 2:15 pm
Best to take it to a shop that can spot-face and have them mill the flats-.030-.050" down just to clean up and give better seating pressure and rod the faces of any cracks/potential cracks. What caused it? Could be many things...poor casting-porosity/improperly torqued (using a impact can do similar damage), sometimes old head bolts are 'stuck' so some mechanics heat the bolt heads and apply hammer torque to break the threads loose...the holes might be out of perpendicularity (but that would have to be quite a bit, +.015" or more). COULD be a combination of thing as as well, nonethesless, it's salvageable. That casting does look a bit porous. Might not have had enough nickle in the mix or maybe it wasn't hot enough prior to the pour...
PostPosted: Tue Jan 26, 2010 9:48 pm
They don't look bad enough to worry about if you have a street engine. You can mill them if you want, but then you'll need to consider cap screw length or the thread height if using studs.
Ken
PostPosted: Wed Jan 27, 2010 7:09 am
I would run it as is, and just throw some hardened washers on those holes. This is not rocket science. I'm sure a machine shop can spot mill them too, as Woody mentioned, which would be the orthodox way to fix it.
PostPosted: Wed Jan 27, 2010 7:44 am
Ive run worse. As Lou says Hardened washers and run as is. If your Really worried Magnaflux the pads.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Jan 27, 2010 12:16 pm
another words run the stud set up (has hardened washers with it) and be happy, gotcha, appreciate all the help guys,
-Mike
PostPosted: Wed Jan 27, 2010 12:39 pm
No need for studs. Hardened head bolt washers are quite common. I use them whenever I mill a block and/or head.
PostPosted: Wed Jan 27, 2010 2:42 pm
I have seen plenty of good running motors at 11:1 and even 12:1 (Tilley) using stock head bolts. Can use washers on them too, yes. Spend money elsewhere unless you are building an all out motor.
PostPosted: Thu Jan 28, 2010 9:07 am
already have the studs, and it will be a boosted motor
-Mike
PostPosted: Thu Jan 28, 2010 2:46 pm
Ok, go for it. Should have washers already with the stud kit...
PostPosted: Thu Jan 28, 2010 2:57 pm
Washers, and dremel out the chips so they're smooth........ (no possible crack propagation)
PostPosted: Fri Jan 29, 2010 12:31 pm
I already smoothed out the little bit of roughness around the pads with a emery board, took awhile, but I wasn't going to risk dremeling too much,
Thanks again guys,
-Mike
