It is currently Thu Jun 04, 2026 11:34 pm
PostPosted: Thu Jan 28, 2010 11:25 pm
New guy here,,,any info on volare clip[under 52 dodge wagon] withv8 spindle mounts[had a 440 in it]to a slant six motor mount kits????Christopher.... ..
PostPosted: Fri Jan 29, 2010 8:32 am
Nothing pre-fabricated exists, sorry. If you want something bolt-in you'll have to get a /6 K-member.
PostPosted: Fri Jan 29, 2010 11:31 am
The drivers side forked mount that captures the spool needs to be one inch taller for a slant. That should get you close.
madam im adam
PostPosted: Fri Jan 29, 2010 4:20 pm
Yeah, I think the driver's side is just a little taller, the passenger side should be the same. As was stated, a kit doesn't exist for this swap. So, trial fit, cut and weld, etc.
Sounds like a cool project ride ya got! 8)
'78 Volare 225
'67 Charger 318
PostPosted: Fri Jan 29, 2010 8:44 pm
thanks for the input/ideas. looks like I will need to do some fabrication work,,thats what makes it fun right?? Christopher.... ..
