It is currently Sun Dec 28, 2025 10:48 pm
 Post subject: Help
PostPosted: Fri Jan 29, 2010 12:10 pm
I REALLY NEED SOME HELP HERE,IM TRYING TO PUT MY SIX ON THE K-FRAME OUT OF THE CAR AND IT WILL NOT MOUNT LIKE IT SHOULD.I DID HAVE THE K-FRAME POWDER COATED AND IS IT POSSIBLE I GOT THE WRONG ONE BACK ?? IT DOES LOOK RIGHT.COULD IT BE LIKE A 318 K-FRAME ??? I HAVE THE CORRECT MOUNTS BUT THE MOTOR SITS TO HIGH AND DOSNT LEAN LIKE IT SHOULD.AM I JUST MISSING SOMETHING ?? ANYONE HAVE A GOOD PICK OF WHAT A K-FRAME FOR A 73 DUSTER LOOKS LIKE,BOTH MOUNTING POINTS ??? ITS LIKE THE MOUNT POINT ON THE PASSENGER SIDE IS TO HIGH AND IT WONT LET THE MOTOR LEAN.HELP.
THANKS,CHUCK
PostPosted: Fri Jan 29, 2010 12:20 pm
It sounds like you have the passenger side engine mount bolted-on up-side-down.
The rubber cushion or spool bushing sits right under the fuel pump.
PostPosted: Mon Feb 01, 2010 6:40 am
HI DOC,THANKS AND I JUST CHECKED IT, INSTALLED THE OTHER WAY IT WILL BE SITTING REALLY WAY UP AND DOES THE OIL PUMP SIT REALLY CLOSE TO THE K-MEMBER ??
IT LOOKS LIKE THE SPOOL WILL BE VERY CLOSE TO THE FUEL PUMP AND VACUME ADVANCE.ALSO LOOKS LIKE IF I TRY THAT IT WILL PUT THE OIL PUMP ALMOST RIGHT ON THE K-FRAME.
IM REALLY LOST HERE AS IM SURE YOU CAN TELL.
DO YOU KNOW ANYONE WITH SOME PICS OR ANYTHING ELSE YOU CAN TELL
PostPosted: Mon Feb 01, 2010 4:06 pm
BTW,
ALL CAPS IS CONSIDERED TO BE SHOUTING.......
So, please don't use all caps.
thanks
PostPosted: Thu Feb 04, 2010 12:15 pm
sorry for being loud
PostPosted: Thu Feb 04, 2010 1:22 pm
... close to the vacuum advance and fuel pump.
Yes, that is how it goes together.
There is enough room, give it a try.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 1 guest
