It is currently Fri Nov 13, 2026 12:43 pm
PostPosted: Mon Feb 01, 2010 5:49 pm
I'm rebuilding my engine and would like to start it on an engine stand first but I'm not sure how to wire it up. I assume batt wire thru ballast resistor to + coil. The starter I'll cable thru relay and use a starter push button to cross the relay. How do I wire the 4-terminal ECU and the 2-wire electronic distributor. Thanks in advance for any help!!
PostPosted: Mon Feb 01, 2010 7:38 pm
Sorry I cant give you a better answer to your question, But this is more of an electrical forum question than an engine forum question.
Also If you get a factoy service manual of the engine bay wiring schematic That should help shed some light on your problem.
Good Luck,
PostPosted: Mon Feb 01, 2010 7:43 pm
Make sure you are using an engine stand designed to have a motor run on it. If you do a google search there are stories of motors flipping over.
PostPosted: Mon Feb 01, 2010 7:44 pm
It's more than electrical........
There's exhaust and cooling to worry about.
and flipping over.
PostPosted: Mon Feb 01, 2010 10:14 pm
Best engine stand to start the engine is your car.I tried it once with what I thought was a sound modified engine stand,first blip of throttle it was on the ground.not pretty.Stuff it.Mark
PostPosted: Tue Feb 02, 2010 6:55 pm
Thanks for the input. I have used the engine stand start up method several times before. But that was before electronic ignitions. If I'm supposed to move this post to electrical I don't know how.
PostPosted: Tue Feb 02, 2010 7:58 pm
try looking in the articles section on this site i would give you a link ,but i dont know how
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Tue Feb 02, 2010 8:39 pm
Good tip. After a few attempts learning how to search the site, found a wiring diagram for the ECU. Thanks again. Great resource site!!
PostPosted: Wed Feb 03, 2010 9:03 pm
How do you plan on starting it? You will need a trans (auto) or flywheel and bell housing. Then how will you attach the engine? I built a test stand for my use it will take any slant configuration.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
Users browsing this forum: DuckDuckGo [Bot] and 2 guests
