It is currently Wed Dec 31, 2025 5:25 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Mon Feb 08, 2010 7:00 am
Car Model: '64 Valiant Convertible
So then the rumors that Dan is a wizard are true... He can see through the miles, across the international border, right into my garage...
My Valiant "IS" Canadian. How does he do it?
What is different? Bell housing? Wiring? Ring gear? Accent?
Thanks. Neilski
PostPosted: Mon Feb 08, 2010 7:08 am
Only his hairstylist knows for sure. :lol:
Ring gear, starter, seal plate, and wiring. It's the same setup as used on '60-'61 slant-6s in the U.S. and everywhere else. Prestolite direct-drive starter with a switching solenoid perched atop it. It's possible to change over, but is it working presently, does the car crank acceptably? If so…why change?
How do I tell what type of starter is on my slant or more to the point, how do I tell what type of starters it will accept?
Your '74 has the gear-reduction starter and will accept the later mini starter if you want to use one.
PostPosted: Mon Feb 08, 2010 7:21 am
No reason to change, the car works fine. Just waiting for a sunny day, and gathering information. Those Canadians really knew how to build a car.
The weather morons are predicting sun for today... Hmmm????
Okay Dan... What's in the shoe box, on the second shelf above the grinder?
PostPosted: Mon Feb 08, 2010 7:40 am
It has taken me a lot of years, dollars, and blood to realise it's best to keep my hands off whatever can be described as working fine.
*shake shake shake*...an answer floats up into view..."Answer unclear. Ask again later."
PostPosted: Mon Feb 08, 2010 9:17 pm
Thanks SlantSixDan!
74 Dodge Charger 225 factory A/C auto 1920 carb stock exhaust.
Mods;
HEI, MSD B3, Magnecor 8 mm, ZFR5N, .060 rotor, CH410X cap, new 3874814 dist, fuel mod, valves hot .010 & .020, all new hoses, JP chain, brake hoses and fluid.
PostPosted: Tue Feb 09, 2010 8:08 am
SL6 Racer
RobbMc performance sells a mini starter for the 66/69 HEMI 4 SPEED cars which used the direct drive starter. Those car use a 172 tooth flywheel and i dont know how many teeth the early torque converters had.Looks like with a drive gear change and maybe an adapter these could be a future option., or a source for the parts required to build one for a slant..
PostPosted: Tue Feb 09, 2010 8:40 am
That'll work on the Slant-6 cars originally equipped with a direct-drive starter, too.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 12 guests
