It is currently Thu Jan 01, 2026 9:35 pm
 Post subject: Vac pot list?
PostPosted: Tue Feb 09, 2010 3:52 pm
Where can I find the vac pot list. I know it exists and I already looked through the FAQ's.
Thanks
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue Feb 09, 2010 4:04 pm
The recuve sticky is where Dan's and Ceej's list should be......or you could do a search......or PM me with your email and I can send you a copy later when I get home.
PostPosted: Tue Feb 09, 2010 6:31 pm
The post you're after is here and probably ought to be in a sticky.
PostPosted: Tue Feb 09, 2010 6:37 pm
Site Admin
It can be found in the Electrical FAQ. I'll link it into the engine FAQ! :D
Still working the bugs out!
CJ
PostPosted: Tue Feb 09, 2010 7:06 pm
Thanks Dan, knew it was here somewhere.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue Feb 09, 2010 7:42 pm
So the vc-208 seems like the pot to have. The only ones I can find have an arm that bends right instead of left.
Anyone find a vc-208 for a points dist.?
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Fri Feb 12, 2010 1:09 am
BUMP
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Fri Feb 12, 2010 7:36 am
There's nothing such as a "VC-208 for a points distributor". You can use the VC-208 if you use a '72 breaker plate, but why go through the hassle for a cruddy system like points? Put in an electronic distributor.
PostPosted: Sun Feb 14, 2010 7:11 am
Or better yet HEI. :D
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Feb 14, 2010 7:40 am
HEI requires an electronic distributor.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
