It is currently Wed Dec 31, 2025 7:37 pm
PostPosted: Thu Feb 11, 2010 6:02 am
I did it. Removing the the manifolds and broke a stud on the lower row :roll:
Searching through the "How to" section I find a lot of information, but some where some one said never use an easy out to remove the remaining section of stud from of the block.
OK I can't find that now..........Murphy sticks again !
What then is the best method to remove the broken piece ? And why not to use an easy out?
"Hewy"
PostPosted: Thu Feb 11, 2010 6:17 am
The EZ out is hardened and will snap off in the hole. Then you cant drill the EZ out out. :D
It is best to drill the hole oversize and use a helicoil ( I like to JB weld them in place).
OR if you can get your drill started right you may be able to drill small hole in stud and increase in size until you can pry the old stud out and just clean up the threads. This has worked a few times for me.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Feb 11, 2010 6:49 am
See here and here, then here.
PostPosted: Thu Feb 11, 2010 7:19 am
Are all lower studs located in the water jacket? What happens to metal chips if they get in there ?
"Hewy"
PostPosted: Thu Feb 11, 2010 7:35 am
Answer to your first question seems to vary by head, according to an old discussion thread I cannot presently locate. Front and rear definitely. A few small metal chips into the water jacket are of no consequence.
PostPosted: Thu Feb 11, 2010 7:54 am
Thanks Dan. I reviewed my first question and noticed I used 'block" rather than head, what I really meant was "head", so I am therefore a "block head ?"
Don't answer that !
"Hewy"
PostPosted: Thu Feb 11, 2010 11:23 am
Drill it out. Then heat it with a torch and use some parafin wax on it. It'll come out witha easy out then.
Can always drill it then just chase the threads witha tap if your really good with a drill.
To many damn dodges and now a slant
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 9 guests
