It is currently Tue May 05, 2026 8:58 am
 Post subject: Drain plug on A904?
PostPosted: Fri Jun 20, 2003 6:48 pm
Is there any good way to add a drain plug to the transmission pan on a 904? I hate having to drop the pan to change out the fluid.
PostPosted: Fri Jun 20, 2003 9:05 pm
6 Pack Dart
I braise a 1/2 20 nut to the pan, then drill through the center of the attached nut and then clean out the hole. You can then use a replacement oil pan drain plug.
PostPosted: Fri Jun 20, 2003 10:48 pm
Or you can go to the boneyard and look for a 904 pan with a factory drain plug, a lot of the later model pans had them.
The aftermarket deep pans (chrome ond non-chrome) have drain plugs.
And for the "meatball" mechanic, one buddy of mine would disconnect one of the trans coolent lines and stick a piece of rubber hose on the end, leading to a bucket or can. He would start-up the engine and pump-out most all of the fluid before dropping the pan. It works pretty good as long as you shut it off as soon as the fluid stops flowing!
PostPosted: Sat Jun 21, 2003 3:36 pm
What later vehicles had 904s? I may be spending quite a bit of time underneath the car tomorrow, so if I can find a place locally to get one today, I'll grab it.
And who makes the best overhaul kits? I found a Fram kit at Schucks but didn't want to grab it just yet.
