It is currently Fri Jan 02, 2026 10:13 am
PostPosted: Mon Feb 15, 2010 8:48 am
hello all.
this is my third post here - please excuse me if this topic has been covered before.
but I would verry much like to hook up a tach and a oil psi guage to my car - as ive always had those two guages in all of my viechles - it comforts me to always be able to monitor those two for something wrong while tooling down the road.
so I have to ask - what are the correct guages for my aplication ?
and how do they hook up ?
id imagine that there is a oil plug somewhere on the engine that I would need to take out and replace with the hook up for the oil psi guage and run that in to the cab of the car - but im clueless as to where the tach would hook up to in a slant 6 motor. if it helps right now im still running the stock points on the car and distributor -
any advice or links to parts I need for this is tremendusly helpful to me.
thanks in advance.
1972 Plymouth Valiant / slant 6 auto
PostPosted: Mon Feb 15, 2010 11:18 am
6 Pack Dart
Green wire goes to points side of coil, put a T fitting behind oil pressure sender unit.
PostPosted: Mon Feb 15, 2010 11:36 am
brian72valiant,
I hooked mine up the same as Fopar. I like running a large tach and a large faced oil gauge for good visibility. Look right under the oil filter for the sender and install a "T" fitting or just eliminate the idiot light. The tach runs right off the coil.
Another useful item is a vacuum gauge. I "T" of the choke unloader or the snorkel diverter line.
PostPosted: Mon Feb 15, 2010 11:48 am
super good info guys.
this seems eazier than I thought.
when I put a tach on my old harley I had to use a gear driven piece off of the cam.... so that was infinately harder to hook up than this will be. haha.
thanks again. im gona get on this right away
Users browsing this forum: Google [Bot] and 7 guests
