It is currently Tue Jan 06, 2026 4:40 am
 Post subject: aluminum block
PostPosted: Sun Feb 14, 2010 1:33 pm
I have access to an aluminum block slant. the guy wants 400 for the block and stock pistons, rods, crank. engine is a 62 i believe. I have a few questions.
will the needed components in my 64 slant(with 904 tranny) transfer to this aluminum block?
is there anything i should be aware of when it comes to milling the block and the head for 9 to1 compression?
are there any dangers when it comes to reliability with the aluminum block?
is 400 a reasonable asking price, or should i haggle down?
thanks much.
PostPosted: Sun Feb 14, 2010 2:08 pm
Welcome on the board. Threads about the aluminum engine, its peculiarities, its limitations, and its worth are here, here, here, here, and here. All internal components are the same except for the upper and lower main bearing caps, the rear main seal retainer and its gaskets. Connecting rods get installed the other way round on an aluminum engine compared to a '63+ iron engine. Cylinder head needs attention to make sure of a compatible match with the block, head gasket is different. Same transmission bolt pattern. If the block is complete with all upper and lower main caps, has no problematic corrosion or other damage, has meat left to bore (not already bored 0.040"), and the cam bearing surfaces are undamaged, then $400 is a good price.
PostPosted: Mon Feb 15, 2010 6:23 am
thanks very much. sounds like the hassle and the extra cost isnt really worth the 80 lbs.
PostPosted: Mon Feb 15, 2010 7:11 am
No its not worth the 80lbs. If you decide to pass on it please pass the contact info on to those who may want it. I know Lou ( Dart 270) is always looking for good Aluminum engines.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Feb 15, 2010 7:31 am
Thanks, Frank... :wink:
If it's really in good shape (no corrosion), then $400 is a fair price. It will be a bit of a hassle to build, especially finding the OEM alum engine head gaskets.
I'm interested in contact info, and if I don't want it, I know someone who probably will.
All the best,
PostPosted: Mon Feb 15, 2010 10:21 am
ill keep you posted. I have a friend that is going there relatively soon to check out a dart. Ill ask him to take a look for you guys.
PostPosted: Mon Feb 15, 2010 11:03 am
Thanks much.
PostPosted: Wed Feb 17, 2010 11:08 am
dart 270, my buddy checked out that dart (which ended up being junk unfortunately) and brought home bad news. The aluminum block is sold. Ill keep my ears and eyes open for one and toss you a message if i find something.
PostPosted: Wed Feb 17, 2010 11:36 am
OK, no worries. Thanks for checking!
Users browsing this forum: curmudgeon and 2 guests
