It is currently Sun Oct 11, 2026 3:13 am
PostPosted: Sun Feb 21, 2010 2:46 pm
Just making sure I understand correctly. I think I read somewhere that I need to remove the little washers on the spark plugs before installing them on my 66 Valiant /6. Yes?
I believe it also said that it could cause big problems if you don't remove the washers. What kind of problems? Seems like it would just space the plug out of the optimum firing area.
Also, does anyone know where I could find some of these tubes? A couple of mine are looking a little ragged on the plug end. Thanks
PostPosted: Sun Feb 21, 2010 2:54 pm
Tune-up parts and technique suggestions, including info on why you don't use the ring washers on '63-'74 slant-6 heads, is in this thread. Plug tubes aren't as easy to find as they once were, but they go by on eBay every now and then, and usually someone here has good ones available (post a "parts wanted" ad). As long as yours aren't too battered, they should be fine. Be sure to use new plug tube seals.
PostPosted: Sun Feb 21, 2010 3:52 pm
Thanks, Dan Got you on the other post too. Mine aren't too bad. Just being safe.
PostPosted: Sun Feb 21, 2010 8:10 pm
Send me a PM if you need a few spark plug tubes.
PostPosted: Sun Feb 21, 2010 9:15 pm
:shock: :shock: and i thought i was " well prepared" by grabbing every dipstick i see!
Image75 dart custom, 225, >10.5-1, hurricane, 500holley, erson cam, 904, 8.8 ford 3.55 or 3.91 aussielocked, 17" steelies, and much more.
PostPosted: Sun Feb 21, 2010 9:52 pm
He's prolly got the rest of the slants somewhere too :D
To many damn dodges and now a slant
PostPosted: Sun Feb 21, 2010 9:57 pm
Remember those contests they had where you would guess how many jelly beans were in the jar to win a prize? I say 60 tubes.
PostPosted: Mon Feb 22, 2010 3:59 am
PM sent.
PostPosted: Thu Feb 25, 2010 1:33 pm
PM Sent.
Thanks,
Bill
1966 Plymouth /6 Valiant Wagon
1969 Plymouth Road Runner
PostPosted: Thu Feb 25, 2010 5:48 pm
I say 120 tubes & 45 "o" rings, Lawrence
Users browsing this forum: Google [Bot] and 13 guests
