It is currently Fri Nov 13, 2026 2:58 pm
PostPosted: Mon Feb 22, 2010 8:30 pm
OK, si I found out my MSD box has to go back to the maker, so I want to run an HEI module for now.IS this way I am running it ok for the coil???
W/ the crescent facing up, right side to the dizzy. I have the bottom left , or C post to the coil NEG. I have the upper post or B to the coil +, AND a toggle switched 12 Volt power on the same coil POS. Will this be fine for the coils life?
If I WERE to run the B post to a switched 12 V power sourse, What would then connect to the coil +??
Thanks in advance....
Andrew/Kidd
Wife's: 64 Valiant
PostPosted: Mon Feb 22, 2010 9:01 pm
Yep, B+ is switched battery power to both the module and coil. If you use a good 30 amp toggle switch and 12 gauge wire you're golden. The HEI module rides herd on coil current so no ballast resistor is required.
6 Pack Dart
Andy see this link
http://duster318.freeservers.com/tech/hei.html
PostPosted: Mon Feb 22, 2010 9:11 pm
I just got the 8.5 MM MSD wires....and the BlasterSS coil.....I know some ignitions that I have "hot wired" to get a car running, the coils got hot w/ the direct 12 volts...... Thanks Josh!!!
Richard, I do like the guys post!!!Thats the one I told you I looked at, apairently I didnt look further down the post. BUT I was still worried about killing the coil!!LOL
Andrew
Wife's: 64 Valiant
