It is currently Sun Nov 22, 2026 10:34 pm
 Post subject: Dropping oil pan
PostPosted: Mon Jun 23, 2003 7:46 pm
Yes I still haven't gotten to it yet :?
So is there any fairly easy way to do it? I don't have access to a hoist, so unless I can get enough clearance around the crossmember with another method, it's gonna wait even longer :x
PostPosted: Mon Jun 23, 2003 8:32 pm
I know people who have done it in the car, but "easy" was not in the description. :cry:
PostPosted: Mon Jun 23, 2003 9:14 pm
Hooooo boy. Looks like I'm in for some gruntin' and cussin' :cry:
PostPosted: Mon Jun 23, 2003 10:16 pm
I have a 73 duster and I dropped the pan with no major problems if I can remember correctly. I just unbolted one end of the center link and swung it out of the way so the pan had clearence to drop. Some of the bolts were a little tricky to take off though but once I found a 1/4 inch drive ratchet with an extension it was easy.
PostPosted: Tue Jun 24, 2003 8:33 am
I could not get the oil pan out on my sons '63 dart - :(
until I got the tie rod ends split and dropped the center link out
of the way. :D
On this car there is only about 1 inch from the center link to the bottom
of the oil pan.
If you have to do it in the car - invest in a good tie rod end remover (the press type that doesn't rip the boots) Pickle fork types
are too destructive :evil: and waste a lot of time in my experience.
PostPosted: Thu Jun 26, 2003 9:17 pm
i have a 70 dart custom and i had to take the tie rods off to drop mine....and i knind of had to lift the block slightly to put it back on b/c of the gasket
dartman69
PostPosted: Thu Jun 26, 2003 9:26 pm
I recently pulled a pan out of a 64 Valiant...I had to drop the crosslink, and jack it up to get at everything...the two bolts blocked by the K-member weren't too bad, once I freed up the motor mounts and pulled the engine up as far as I could get it.... :roll:
If I had to do this on my duster, I'd just pull the motor and refresh a few other things...I think it'd be easier...
Users browsing this forum: Google [Bot] and 8 guests
