It is currently Fri Jun 19, 2026 3:19 am
PostPosted: Mon Feb 22, 2010 1:58 pm
Trying to find a power steering unit for a 1976 Plymouth Volare. I think the pump is out which caused the unit to cease operation. I don't know. Can anyone help?
PostPosted: Mon Feb 22, 2010 2:07 pm
(1) is there fluid in the pump?
(2) is the belt attached to the pump?
(3) is the belt tight?
(4) does the gearbox or pump leak excessively when fluid is added?
PostPosted: Mon Feb 22, 2010 2:12 pm
there is fluid in pump, but it leaks and now the steering wheel will not turn at all in either direction. The belt is good and tight.
PostPosted: Mon Feb 22, 2010 2:48 pm
Even if the power steering pump fails the wheels should still turn. It will just be more difficult to turn the wheels. Is it hard to turn the wheels or is the steering truly locked up and not able to turn?
PostPosted: Mon Feb 22, 2010 5:04 pm
I'll have to check. It is my son's car. It seemed that he turned the wheel and the tires didn't turn, but I'll check it out. I'll let you know tomorrow. Thanks for responding.
PostPosted: Tue Feb 23, 2010 8:59 am
I rebuilt my P/S pump using a kit from my local parts place; I need a special tool to pull and install the pulley, but otherwise it was simpler than rebuilding a carb (note - there was a note about which of O-rings to use in the kit on the back side of the instructions where you might easily overlook it).
PostPosted: Tue Feb 23, 2010 4:44 pm
If the p/s pump goes bad, can it cause the box to go bad also? And do you know if the Volare has rack and pinion? Thanks
PostPosted: Tue Feb 23, 2010 4:49 pm
Recirculating ball steering, not rack and pinion. I could see the pump eating itself and dumping trash into the gearbox and causing it to fail, but I have to believe it's a race occurrence.
PostPosted: Tue Feb 23, 2010 5:03 pm
race occurence?
PostPosted: Tue Feb 23, 2010 5:10 pm
Rare occurrence, sorry.
PostPosted: Tue Feb 23, 2010 5:15 pm
No, I meant what does that mean?
PostPosted: Tue Feb 23, 2010 5:16 pm
Sorry, A little slow.....
PostPosted: Tue Feb 23, 2010 6:05 pm
A rare occurrence means something that does not happen often.
