It is currently Sat Oct 10, 2026 6:02 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Wed Feb 24, 2010 3:25 am
OK, fast may you ride...
PostPosted: Wed Feb 24, 2010 5:18 am
When I put my turbo motor together, using a copper head gasket, I used Hylomar in a spray can on the gasket. First time using the copper gasket. It was together for about 3 years with absolutly zero coolant or oil seepage. Got the Hylomar from either NAPA, or Carquest. I like it.
PostPosted: Wed Feb 24, 2010 3:20 pm
charlie is that the same as the spray/ adhesive you can get at the chrysler dealer, they use it on the 2.0l steel head gaskets, thats is what i used on my copper gasket with no problems.
PostPosted: Wed Feb 24, 2010 3:54 pm
Will be torqueing to 65 lbs not 85 like I thought.We will see.Mark
What is your reasoning behind that?
Owen
PostPosted: Wed Feb 24, 2010 5:26 pm
7/16 Arp studs recomend 62lbs.Wonder how much more I could go.Guzzi Mark
PostPosted: Wed Feb 24, 2010 5:47 pm
My directions say:
70lbs w/arp moly lube
85lbs w/30wt oil
65lbs w/aluminum block and moly lube.
11.02 @ 120.56
Chassis dyno
PostPosted: Wed Feb 24, 2010 6:35 pm
I was at the Chicago Connection tonight. Bill stocks Hylomar in the spray can there. :shock:
PostPosted: Wed Feb 24, 2010 7:00 pm
I used Hylomar on my copper head gasket as well. Nice stuff. Found a bunch at a local swap meet for $3/can/tube. Bought a bunch :D
11.02 @ 120.56
Chassis dyno
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
