It is currently Sat Jun 13, 2026 10:05 pm
PostPosted: Sat Feb 27, 2010 4:49 am
We called around and looked on the web but no luck. So I made these for the 72 Duster 225. These are made of 3/16" solid steel, fully welded direct replacement motor mounts. This set was made for testing so they do not have a sale finish just 50 passes in the quarter mile and burnout pit. We will sell these and offer them powder coated in any color and what about chrome mounts? thanks for your input on this Don.
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
Last edited by Mister Twister on Wed Mar 03, 2010 4:00 am, edited 1 time in total.
PostPosted: Sat Feb 27, 2010 5:03 am
Great race Poly mounts are now available. If your more serious than that Motor Plate is the best route.
My02.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Feb 27, 2010 7:14 am
Thanks for your input 66aCUDA. :) How much is one of these plates? Do they take up much room? Have not seen many of these for the slant. With the motor mounts being easy to see, I think they would dress up the engine compartment nicely for the car shows and give us added strenth to boot!! :mrgreen: JMO Don
My Twister Page
PostPosted: Sun Feb 28, 2010 10:32 am
While I don't need any of these right now, let me say kudos to ya for fabbing up parts that slanters might need! :bow:
A little chrome might look nice in the engine bay.
'78 Volare 225
'67 Charger 318
PostPosted: Sun Feb 28, 2010 5:15 pm
edd j. sells motor plates for the slant
http://www.pacefabrication.net/
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sun Feb 28, 2010 5:20 pm
Edd at Pace +1
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Feb 28, 2010 11:00 pm
I have a pair of solid mounts in my '66. It took me about 30 minutes to lay them out, and Patrick another 15 to do the welding on them. I simply used a couple pieces of scrap 2X2 box tube. No big deal.
Motor plates are nice, but to do them properly you also need to add fore/aft movement limiters.
Both solid mounts and plates will get you used to checking most all fasteners on the car to see if they've backed off since last time you ran the car. :lol:
PostPosted: Mon Mar 01, 2010 4:27 am
Good morning and thank yall for your input on these solid motor mounts!!
:) A little more work to install one of these!!!
Sure takes up alot of room, stopping the air flow somewhat. Hole drilling for mounting. :shock:
I think it took me 1/2 hour to install the solid mounts and have not touched them since the install. Does this plate change belt line up? What about A/C or power steering? This just looks like it would be nice for a race car. Not a show car JMO to much work for the install Don. Did you see how much they cost? Motor Mounts less than $50.00 now that is a money and time saver, time is money!! Have a good day all Don. :arrow:
My Twister Page
PostPosted: Mon Mar 01, 2010 9:38 am
Everyone run,its the grammar police !!!!
Twister : I like it. An old trick is running a solid mount on one side and a rubber mount on the other. Kind of the best of both worlds.
PostPosted: Mon Mar 01, 2010 1:05 pm
My wife Christine is a university professor and one of the smartest people I know (really). She can't spell worth a $@$%.
PostPosted: Mon Mar 01, 2010 2:21 pm
Then how'd she end up with you? :lol: :lol: :lol: :lol: :lol: :lol: :lol:
j/k :D
PostPosted: Mon Mar 01, 2010 2:35 pm
OK, I asked for that one...
PostPosted: Mon Mar 01, 2010 2:55 pm
For the Biscut Type a body Mount Left side. 67-72 a body. I just got a Moroso A body - a engine solid Mount and shimmed it to be the Correct Height I have one on the dart and on ruster.
For the passenger mount I pretty much did what mister twister did.
I don't think there is much of a market for solid mounts when you can easily make them with a mig and some scrap steel or get the engine plate.
PostPosted: Sat Mar 06, 2010 7:20 pm
Does it Help Handling? Not that I know of.
It helps secure the engine to the frame/ drivetrain eliminating unwanted excess movement and getting more power to the wheels and not losing it through excess momentum shifting in the chassis.
Others will chime in too I am sure.
PostPosted: Sat Mar 06, 2010 7:31 pm
In theory, moving the motor back will help the car hook. However, when dealing with a Slant in a heavy car I am pretty sure it is a moot point. :shock:
Will it help handling? I'll leave that to Josh or Lou to debate with you. :D
