It is currently Mon Jun 15, 2026 7:50 pm
PostPosted: Tue Mar 02, 2010 1:53 pm
Looks like one (and only one) set of lower control arms for A-bodies in '73 and '74. No listing for "W/ anti-sway bar" vs. "W/O anti-sway bar". So how was the bar mounted in '73-'76?
PostPosted: Tue Mar 02, 2010 3:36 pm
Not sure, but probably something like the C body/isolated K frame B body set up, with the end links bolted to a bracket that wraps around the strut rod.
PostPosted: Tue Mar 02, 2010 3:57 pm
Image OOOOH OOOOOOH I KNOW!
That's from my 74 FSM. Looks like a bracket welded onto the front of the lower control arm.
PostPosted: Tue Mar 02, 2010 4:00 pm
Okeh, but then the question is whether all of the '73-'76 LCAs have the bracket…given that there's no separate part number given for "with" vs. "without".
PostPosted: Tue Mar 02, 2010 4:04 pm
Nope. The LCAs on my brother's 74 Duster have no sway bar bracket. www.car-part.com lets you search for with or w/o sway bar brackets.
PostPosted: Tue Mar 02, 2010 4:11 pm
Interesting. FPC fail! :roll:
Wonder what else is missing from cars not factory equipped with sway bar.
(it's peanut butter jelly time…)
PostPosted: Tue Mar 02, 2010 4:16 pm
I would hazard a guess cars not equipped with a sway bar are missing two tabs welded to the LCA, the sway eliminator, two links, ten retainers, two sleeves, two supports, eight insulators, six nuts, four bolts, and four washers. :mrgreen:
PostPosted: Tue Mar 02, 2010 4:19 pm
Hold still while I throw this end wrench at you.
I said hold still, dangit!
:lol:
PostPosted: Tue Mar 02, 2010 4:24 pm
PostPosted: Mon Mar 08, 2010 2:02 am
And a partridge in a pear tree.
PostPosted: Tue Mar 09, 2010 9:44 pm
I agree with Reed. I had to add all that recently...
