It is currently Tue May 05, 2026 2:53 am
PostPosted: Wed Jun 25, 2003 1:56 pm
Hello :D
I have a 1973 Dodge W 100 4X4 Power Wagon that has a 3 speed manual tranny on the column and was wondering if an 4 speed overdrive tranny from a 1980 Dodge Van would bolt in. They both have a slant six engine.
Any information would be appreciated--Thanks!
Kevin :)
PostPosted: Wed Jul 09, 2003 9:54 am
I believe the bellhousing will have the pattern for the OD trans, but I don't know about the driveshaft length or shifter location.
You could use the BH and clutch/flywheel from the '80 Van too, and there are no swap issues with the crank pattern - they are the same.
