It is currently Tue Apr 28, 2026 6:37 pm
PostPosted: Wed Jun 25, 2003 7:12 pm
I'm confused about the compatibility of a pre/post 67 slant transmissions, with a 66 225. The slant that I'm building is a 66 block with a 66 crank so I would need to use a 66 or older tranny right? What is the reason for this?
PostPosted: Wed Jun 25, 2003 8:54 pm
I think you can use the '67 transmission-it's the '68 and newer cranks that had a bigger pilot hole in them for the torque converter hub or pilot bearing.
PostPosted: Thu Jun 26, 2003 8:57 pm
You can use the early small pilot crank with a late trans if you get a converter made with a small snout on it. :shock:
http://www.slantsix.org/articles/hrm-sl ... ov-pg2.jpg
