It is currently Sat Jun 13, 2026 9:04 pm
 Post subject: Supercharger head gasket
PostPosted: Thu Mar 04, 2010 4:15 pm
Hey guy/gals, I am building a slant with an eaton m90 bolwer. I plan to run approx 10psi with stock compression and .40 overbore. Just wondering what head gasket will get the job done.
Thanks
225 m90 supercharger model T roadster project
PostPosted: Thu Mar 04, 2010 5:12 pm
Stock compression and ten lbs, you should be able to use a stock type gasket, as long as you stay out of detonation. If you feel you need something more, copper gaskets are available, from Hussey Copper.
Which Englewood are you from, near Jacksonville, or down by Bradenton?
PostPosted: Thu Mar 04, 2010 8:39 pm
If you decide you want a heaver fire ring than a standard Fel-Pro. I stock the Permaseal Aussie head gaskets.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Mar 04, 2010 9:06 pm
I agree with charlie,NOS steel head gasket,10 LBS of boost and NO problem! But you must be sure the head and block surface are true.
PostPosted: Fri Mar 05, 2010 2:01 pm
I have been running an aussie permaseal head gasket in my procharged slant at 12lbs boost with no problems what so ever. The only thing, like suggested in one of the other posts is stay out of detonation. Best to invest in a wideband O2 for tuning on a boosted application as well.
Users browsing this forum: Amazon [Bot] and 2 guests
