It is currently Wed Oct 14, 2026 7:27 am
Post new topic  Reply to topic  [ 47 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Fri Mar 05, 2010 1:56 pm
The pistons are Down .0025" to .008" Most are .005"
Why the .055" spread in deck heights? Crank indexed poorly?
PostPosted: Fri Mar 05, 2010 2:03 pm
Check your math! .0055"
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Mar 05, 2010 2:19 pm
Sorry, dropped a zero, typo not a math problem. Still over 5 thousandths isn't cool. It's probably the crank.
PostPosted: Fri Mar 05, 2010 2:45 pm
Or a non parallel top deck to crank main line... if you see a consistent increase / decrease, end to end.
PostPosted: Fri Mar 05, 2010 6:57 pm
Could be rods too.
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Mar 05, 2010 7:20 pm
Mine are .010 down.My block was decked a little more,I also took .020 off the pistons to get them there.I also sanded a couple to get them closer.I am actually .009 to .011 down.
I dremeled my pistons today for the valve clearence,will do final kiss tommorrow and check again with least bent valve.One allmost survived.Exhaust are a little to close for my likeing also.Guzzi Mark
PostPosted: Fri Mar 05, 2010 7:36 pm
Should have been easy to know where to grind :(
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Mar 05, 2010 7:58 pm
Far from easy or fun,worst part of build so far,my back is killing me.Haveing motor back 1.5 inches didnt help on number 6.Guzzi Mark
PostPosted: Sat Mar 06, 2010 3:20 pm
Well No they are not consistent from front to rear.
They seem to be random.
I dont have the #'s for each one with me now - They are on a notecard at home.
I will have to post them.
PostPosted: Sat Mar 06, 2010 4:08 pm
Could be rods too.
If K1 did that to their customers I'd be unhappy and surprised. The deck heights of the 170 I tore down were also way off. I'm having the crank stroke and rod lengths checked. The pistons are within 1/2 a thousandth of one another.
PostPosted: Sat Mar 06, 2010 4:41 pm
If you recall, K1 did have a problem with the tang being machined on the wrong side of the rod and cap. Never say never. They admitted the mistake and fixed it...no big deal. Probably not the pistons either. I don't have them in my engine yet to check the height but the diameter of all 6 measured within .0003". Four are within .0002" of each other.
11.02 @ 120.56
Chassis dyno
PostPosted: Sat Mar 06, 2010 8:27 pm
thanks greg for pics. my guess from pics 4 , 5 , and 6 at about the 2 o'clock area looked like -.080 to -.100. i was way off . ronnie
PostPosted: Sat Mar 06, 2010 8:32 pm
When it comes time to cut valve reliefs in my pistons I'm going to use a transfer punch through the valve guides to mark the valve centers. Since the reliefs will be cut in stock replacement type forgings they will be as shallow as is practical.
PostPosted: Mon Jun 20, 2011 7:01 pm
Dang Mark, thats a drag. I still have to come by and say hi, Im working tomorrow after 11 days off. Will pop in and introduce myself if Im on the good side of town (rarely!)
PostPosted: Thu May 21, 2015 1:29 pm
I know these are very old posts but was wondering if Wiseco ever changed the valve notches on the new pistons? We will have 2 motors going together shortly and was just wondering.
Rick
