It is currently Thu May 21, 2026 11:30 pm
PostPosted: Sat Mar 06, 2010 8:30 am
Would it fit? Does anyone have width numbers?
I found an 87 Dakota with 3.55's and a sure grip in a yard.
i'd like to put it in the Volare if it would fit.
PostPosted: Sat Mar 06, 2010 10:18 am
I don't think so. I have an F-body rear end i was gonna put in my dart. It has 2.73s, but that is a much narrower rear end than the dakota. I was told in a thread below this, that the dakota rear is 62+ inches. I think that, thats at least 4 inches wider than the F-body rear. You would have to get some wild offset wheels, and that'd still be a squeeze!
PostPosted: Sun Mar 07, 2010 10:31 am
I measured my Volare rear at 59 1/2" drum to drum and the Dakota rear is 63 1/2", 4" to wide. I guess I'll be pulling the gears and sure grip to swap into the volare and I'll have a complete set of 10" brakes for sale.
PostPosted: Sun Mar 07, 2010 11:46 am
A 65-70 B Body 8.75 is almost a drop-in on a FMJ.. The springs need either pushed in or out just a tad and the housing drops in. Pulled a 70 B 8.75 out of the 80 Cordoba I parted out - looked like it was factory installed. At this point in time I don't have a need for the housing but am keeping the 3.23SG from it.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Sun Mar 07, 2010 12:58 pm
I really don't want to swap rears, sepecally to an 8 3/4. I don't want to have to get a drive shaft cut, find shock plates... I just want better gears and a sure grip.
PostPosted: Sun Mar 07, 2010 1:48 pm
'68-'70 B-body 8 3/4 rear ends are wider than the '65-'67 rear ends. The later rear end is probably a better fit for the FMJ.
PostPosted: Sun Mar 07, 2010 8:06 pm
I wish you were closer; I'd take that housing/axles off your hands!
so in the meantime I'm building a 8-1/4 with 3.55s and a brand new Trac Lok (Spicver's version of a Sure Grip, was OEM for the later years) should be plenty strong for my intentions.
Users browsing this forum: No registered users and 18 guests
