It is currently Sat Jun 13, 2026 5:14 am
 Post subject: F body manual steering
PostPosted: Sun Mar 07, 2010 8:40 pm
Car Model: 1964 Valiant
Is the manual steering box for an A-body the same as a F-body?
Most of the f-bodies seem to have power steering.
PostPosted: Sun Mar 07, 2010 8:43 pm
Yes, the manual steering boxes interchange although the pitman arm may not.
PostPosted: Fri Mar 19, 2010 1:32 pm
Yes But as josh said The pitman arm poses problems.
Get a Manual box from a van say 73-77 and it' a direct bolt in without a pitman arm hassle.
Check steer and gear:
http://www.steerandgear.com/SteerandGear/index.html
They have them in stock - Good stuff from these dudes.
PostPosted: Fri Mar 19, 2010 9:26 pm
I came across a '52 Dodge B series "Pilothouse" 1/2 ton
with the Volare subframe installed. It has no steering or
motor. I am not going to purchase this truck, just curious
about an abandoned project and whether the K-frame
is installed correctly. The Volare setup fits very well and
does not appear hacked.
