It is currently Sun Nov 22, 2026 8:06 pm
PostPosted: Thu Jun 26, 2003 3:39 pm
Are slant six valve covers interchangeable thru the years? I want to use a clean '62 cover on a later motor, but the later cover seems taller. is this correct?
PostPosted: Thu Jun 26, 2003 3:58 pm
1960 -79 all interchange, when the Slant 6 got hydralic lifters, the valve cover got wider. Look-up the valve cover gasket years, you will see two different ones called-out.
Note that the breather, PCV and oil filler hole positions all moved around over the years.
Users browsing this forum: DuckDuckGo [Bot] and 12 guests
