It is currently Mon Jun 15, 2026 4:48 am
PostPosted: Mon Mar 08, 2010 7:46 am
Car Model: 1967 Dodge Dart GT
ive got a set of aluminum et mags, vintage, they have slots that you can put in different washers, were off a duster, but i dont have the washers, anyone know a good source for those? wanting to put my disc brakes on the front before it gets warm enough to get the dart out more. i have a set of steel slotted mags that have peeling chrome, but want the disc brakes, so going for as close of a match as i can, ie, not 13" rear stocks and 14" slotted fronts.
thanks!
PostPosted: Mon Mar 08, 2010 9:17 am
These guys http://www.evergreentire.com/ always have whatever special washer or lug nut I need in stock. Very reasonable prices. There are also vendors on eBay or Jegs or Summit that sell what you need.
Could you post a picture of the steel slotted rims? Sounds interesting. Are they 14 or 15 inch rims? Are they the late 70s Dodge truck rims?
PostPosted: Mon Mar 08, 2010 11:32 am
i believe theyre 14", bought as a set at an auction, sold as being off a duster, believe i checked the front steel ones before and they are sbp which wouldnt be on a truck iirc. the mags are in illinois, going home weekend after next and will bring them back to indy then. thanks for the info, emailed that place.
PostPosted: Mon Mar 08, 2010 11:38 am
Interesting. Good luck!
PostPosted: Tue Mar 09, 2010 8:26 pm
Are you talking about the unilug washer to change the bolt circle? those only go down as far as 5X4 1/2" is that the bolt pattern you intend to run?
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Wed Mar 10, 2010 9:49 am
thanks for the info, i intend to run them 5x4 for the time being, would assume if they were on a duster would be sbp somewhere since the front ones are as well, but could obviously be wrong!
PostPosted: Wed Mar 10, 2010 10:06 am
I have seen unilug wheels that were SBP.
