It is currently Tue Oct 13, 2026 4:54 pm
PostPosted: Tue Mar 09, 2010 8:55 pm
My nephew has a 70 dodge charger. He had the gauges reconditioned and after I reinstalled the cluster (that sucked, big time) the needles just float around. Could it be a bad dash voltage regulator? I did run a fresh ground from the dash cluster to a good ground.
In a (probably) related story, the car just doesn't charge at anything like idle. The alternator has been rebuilt, and the voltage regulator has been replaced. Any guesses? I am ready to give up.
I'm sure I can do this without disconnecting the battery. What could possibly go wrong?
PostPosted: Wed Mar 10, 2010 9:07 am
Check the dash ground and feed to the voltage limiter carefully. You can put a test light on the temp sender connection - it ought to come on at full +12V, then start blinking on and off ~ 2Hz-ish (not entirely regular is normal). If you see much less than +12V when it's on, you've got a poor connection on the hot side.
If the problem gets worse with dash lights on bright, it is definitely a ground problem.
 Post subject: thanks
PostPosted: Wed Mar 10, 2010 6:08 pm
KBB, thanks a lot. I will check that as soon as I can get over there...
