It is currently Thu Nov 26, 2026 6:58 pm
 Post subject: carb and intake question
PostPosted: Fri Mar 05, 2010 5:04 pm
I have a 66 valiant with an auto trans and a 225 engine that is stock with only 30,000 original miles. I want to upgrade to a two barrel carb. I was thinking of either the Holley 2300 or 5200. I would use it on a used slant six two barrel intake with an adaptor for the Holley.
Do you think that the 2300 350cfm is a better choice? I also have air cond. Is there any difference I need to know when choosing an intake? Will all two barrel intakes match up with my existing exhaust manifold?
I have the cable style throttle which should work and I know I will have to modify my trans kick down and choke.
Thanks for the info
rick smith
PostPosted: Fri Mar 05, 2010 5:10 pm
For a stock 66 motor, I would recommend the Holley 2280 carb. The Super Six intake should work fine with A/C.
PostPosted: Thu Mar 11, 2010 7:07 am
there are two 2280's on ebay right now. bid starts at $
100.00 or buy it now for $125.00
http://cgi.ebay.com/ebaymotors/New-Holl ... ccessories
PostPosted: Thu Mar 11, 2010 7:45 am
See this post for manifold ideas and link to less-expensive new Holley 2280.
