It is currently Wed Nov 25, 2026 12:14 am
PostPosted: Fri Jun 27, 2003 12:25 am
I'll try to make this as clear and simple as possible, but here it goes.
I own an '83 RAM D150 /6 2 barrel. I have been working on it for the past three months getting it driveable again and repaired such that it will pass NC State Emmisions Inspection. Unfortunately, the Inspection Technician had been unable to explain an error code the machine was giving off that stated there was 'Excessive Dilution' during testing. I had to call the DOT finally to get an explanation. I was told that the vehicle was idling inconsistantly, a fact I had noticed when the tech had the tach hooked up. It was idling between 800 and 975 RPM's.
Now, in an attempt to begin correcting this problem, I performed a tune-up, replacing wires, plugs, ditributor cap and rotor button, PCV valve and fuel filter. I know this alone will probably not fix the actual problem, (possibly a vacuum leak?) but I'm working toward two goals. One is to get the truck running right. Two is to spend at least $200 in emmisions related repairs so I can apply for a waver for one year.
Since I only understand the principles behind carbeuration and not the mechanics, I decided to leave that until last to work on.
In the mean time I decided to replace the dual magnetic pickups which I had noticed were covered in rust when I tuned up. After a good amount of effort and self education, I got the reluctor out, the new pickups in (properly gapped) and the rest reassembled.
Here's where it get's interesting. Before I replaced the pickups, the truck ran fine. It started every time I turned the key. Now, I have to play around with the distributor to get it to crank. And it runs fine after I get it started. One thing I had noticed is that the rotor button seems to get 'stuck' in one position, whereas I can crank the engine, but the distributor will not turn. If I manually turn it to one side of the play it has and crank the engine via the fan, it will then fire up. The only explaination I can come up with, keep in mind I'm not a mechanic, is that somehow I have a dead spot in the distributor drive gear. This theory would also explain a small hick-up the engine has at idle in that the distributor hits that dead spot, continues on through momentum, re-engages and fires a few degrees late.
Now I'm bold enough to try and replace the drive gear myself. Except I can't seem to get the distributor out of the block. I removed the hold down clamp but can only seem to move it a quarter of an inch at most.
I guess what I'm asking is, is my theory close? Should I just take it to a mechanic and have them replace the drive gear or distributor if necessary? What else might be causing the dynamic idling? Any thoughts or suggestions would be appreciated. And sorry for the novel. I don't know how else to get my point across. Thanks
PostPosted: Fri Jun 27, 2003 8:13 am
our theory sounds pretty good. Slant sixes came with a plastic distributor drive gear. These are known to crack and break. You can buy a replacement gear at almost any auto parts store. As far as getting the distributor out just remove the holddown bolt and give it a good tug. Replacing the gear is a very easy job and should take about half an hour tops.
Reed
PostPosted: Fri Jun 27, 2003 9:35 am
NAPA carries a cast iron distributor gear if you need one of those.
Echlin # DG-404
PostPosted: Sat Jun 28, 2003 1:22 am
Thanks for the reassurance guys. I'm going to give it one more try before I take it back to the mechanic. It was suggested to me that the distributor has probably never been pulled in the 20 years it's been on the road. And that crud has built up around it keeping it from coming out. I'll get some carbeurator cleaner and give it a good soaking and try again. I swear, if the truck had AC, I'd get rid of that POS Neon I drive. Thanks again.
PostPosted: Sun Jun 29, 2003 1:33 pm
Since you mentioned a lean burn ignition, I'm going to throw in my two cents...
Have you tried holding a timing light on it while it idles? I had a very similar problem with my '87, and it turned out my timing was wandering 7-8* :shock: Mine turned out to be the computer going south (could also have been a worn distributor shaft/gear) , so i 86'ed the lean burn and installed an MSD 6A ignition (also requires a standard electronic distributor, only one pickup on these). Never had any timing or idle issues since...even my mystery/random misfire at idle dissapeared.
My .02 in short--ditch the lean burn, grab a new/rebuilt electronic dist, MSD Ignition, wires, and coil. Other than making the plug wires with a cut-to-length kit, the whole install only takes about an hour, and the whole setup can be had for around $250 (depending on prices in your area). JMO
-S/6
The "Silver Bullet"
87 Ram D150
PostPosted: Sun Jun 29, 2003 3:05 pm
Well, the saga contiunues...
I went to try and crank it, forwarding the rotor until it engaged. After a few tries I noticed the play had gone from a few degrees to almost 180. I was hoping to get it started so I could go pick up a lawn mower. :( The MSD sounds like a good idea, but it will probably have to wait until next year in case I have to do the spend $200 for a waver thing.
PostPosted: Wed Jul 09, 2003 11:30 pm
For those of you interested...
I eventually got the distributor out. The drive gear was half gone. I ordered the new one from NAPA, thanks Doc. There were a few days between when I took it apart and when I put it back together. So, naturally, I did it wrong. And since I hammered the new roll pin in as far as I could, I had to have a friend pull it back out for me. He did clean it up a little more though, nice and shinny. While it was out, I noticed the number '1' punched in the side of the housing. I thought it was safe to assume that this indicated the position for the No1 spark plug wire. Funny thing was that this position WAS for the No3 plug before I took it out of the block. Best I can figure is that the old gear slipped 240 deg or someone had removed it and couldn't get it back in right. After I get this in, I may tackle the carbeurator. Wish me luck.
Edit: I was wrong. I checked the manual to be sure. The number '1' stamped onto the housing doesn't mean squat apparently.
Users browsing this forum: DuckDuckGo [Bot] and 9 guests
