It is currently Fri Nov 13, 2026 7:19 am
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Mar 14, 2010 7:24 am
Mike, Not much help here but I do know that the S-10 89 or later has the electronic speedo. You can convert this to the regular speedo with an easy fix. I found some great info on the HAMB. Do a search for Flat Ernie, he has a lot of info on the T-5. Hope this helps you!! Let us all know. 8)
Bud
Did that hurt right away or did it wait awhile?
PostPosted: Sun Mar 14, 2010 3:32 pm
Well I got my "How to rebuild and modify your manual transmission" the other day been reading it pretty intensely found that the '94-95 stang T5 has a input shaft length of 7.85", what is the length of the input shaft of an A833OD ?
-Mike
PostPosted: Wed Mar 24, 2010 8:27 pm
*BUMP* So what is the input shaft length for the A833OD transmission ? This guy is starting to irrate me at his lack of ambition to sell his tranny, and I'm ready to snag a boneyard v6 trans cause they are plentiful, but they are also a road trip away (there in Sarasota,fl and I'm currently in Jax about 270mile diff) so I just need to if a v6 is worth the trip,
-Mike
