It is currently Sun Nov 15, 2026 9:51 pm
PostPosted: Fri Mar 19, 2010 5:28 pm
I hope this is the right place to ask this. I have a 1987 dodge ramcharger with a 360/727. Yesterday I blew the tranny. I found a d150 with a a998-999 tranny with lockup converter. they guy wants $200 for the whole truck including a good spare 318. My question is how do it make the lockup tranny work behind the 360?
To each his own (so what if I wanna build a 450 horse MPFI turbo /6 instead of using a V-8!)
 Post subject: You will need...
PostPosted: Fri Mar 19, 2010 5:47 pm
Everything should bolt up although the A998/999 might not live too well behind the 360... also your 360 is externally balanced so you will need a Lockup A904/A998/A999 torque convertor for a 360...
PostPosted: Fri Mar 19, 2010 5:58 pm
Could I possibly just weld the weight to the 318 convertor?
PostPosted: Fri Mar 19, 2010 6:27 pm
There is a balancing kit available, I believe from Mopar Performance that will do what you need. It bolts to the flex plate if I remember correctly.
I had the same problem once with a 69 Dart; I ended up having a slug of steel welded on to the converter. It wasn't pretty but it worked.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Mar 19, 2010 6:38 pm
Sounds like its doable, but do any of you guy's have some ideas on driveshaft lenght and getting the lock-up converter to work, or will it be ok to run it unlocked?
PostPosted: Fri Mar 19, 2010 8:58 pm
is the Ramcharger a 4X4? If so then the D series trans wont work (2WD)
Personally I have done several 904/999>727 swaps but never the other way around.
PostPosted: Fri Mar 19, 2010 9:23 pm
Do not weld to a lock-up converter. You will ruin the clutch material in the converter. Get a B&M or other counter weighted flex plate.
PostPosted: Sun Mar 21, 2010 4:59 pm
The ramcharger is 2 wheel drive and so is the parts truck. I'll check on the counterweighted flex plate but it's starting to sound like I should just have the 727 rebuilt! Lots less trouble and about the same money. :roll:
PostPosted: Fri Apr 02, 2010 4:46 am
And you'll end up with a better transmission. Plan B looks good.
PostPosted: Mon Apr 05, 2010 7:34 am
No it's not... this is a slant six forum :wink:
