It is currently Mon May 25, 2026 1:46 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Sun Mar 21, 2010 7:03 pm
Car Model: 64 Valiant
Couldn't a person just use a head gasket as a pattern and have a plate plasma/water jetted to match? The price of the 1 1/2" plate would be the killer. Does it have to be that thick? Could a person use 3/4" - 1"?
The more similar you can make the plate in thickness to the actual head, the more accurately it will simulate an actual head being torqued on the block. Also, you don't have to make the plate as wide as the real head, just only wide enough to reach to the pushrod area, beyond that has no affect on the cylinder walls, so that might make the initial cost a little cheaper(plus lighter). But im sure that having a 3/4" to 1" plate would be better than none at all, just add some spacers under the bolts to make up the difference.
PostPosted: Sun Mar 21, 2010 8:29 pm
In a pinch I have used a block of iron and a head bolt on all 4 corners and just moved it down the head as I hone it.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
