It is currently Mon Dec 29, 2025 3:46 am
PostPosted: Tue Mar 23, 2010 5:58 pm
MAybe I should get rid of it before I do something................CRAZY?!?!
I got a good supercharger and intercooler from a Chevy Cobalt......And Have been dreaming about my 65 D100 with the SC/. I have read through some topics but am at a loss. Heavy modifications no matter what, but I have an idea every year or two! Eaton m62.
What would you do???
PostPosted: Tue Mar 23, 2010 6:10 pm
Dumb idea #1: Run it off the driveshaft, blowing thru the carb
Dumb idea #2: Mount it to the A/C compressor bracket, belt drive it, blow it thru the carb.
Dumb idea #3: Mount it on the hood, mate it to a starter motor, hit it only when you want it Mad Max style
Dumb idea #4: Mount it to a mountain bike, hang the mountain bike tire out the window to the ground when you want it to kick in.
Dumb idea #5: Mount it on top of the air cleaner. Mount a propeller to the front of it. The faster you drive, the faster it spins.
I'm spent.
1965 Valiant wagon Turbo slant (work in progress)
2000 Chevy 155" cargo van - The Abductor
1970 Newport convertible
1996 Buick Roadmaster Wagon
1966 CruiseAire motor home
1990 Toyota 1 ton box truck TURBO slant (scraped)
PostPosted: Tue Mar 23, 2010 7:00 pm
(Thus requiring a total overhaul of the brake system. cuz the faster the driveshaft turns, the more boost/ speed. and no matter what it will go faster, n faster, n I cant stop goin faster, n faster)
( requiring I install A/C on my 65, wich is a total pain)
(I'm not sure my charging system/ Battery could handle the load, but would a cranking handle lessen that effect? And would the hood ribbing support the torqe loading?)
(I like this idea! I live in the mountains!)
( Now I'm confused? At high sppeds, This would seem to cause excessive lift? I am not into aeronautic's, just old /new auto's)
 Post subject: Nitrous!
PostPosted: Wed Mar 24, 2010 4:07 am
Don't forget, that whatever dumb idea you choose, that you must then add a 300 shot of nitrous to it. That will smooth out all the rough spots and make all that labor and engineering worth your effort! :)
Rick
PostPosted: Wed Mar 24, 2010 7:28 am
You DO know I sell the Aussie Speed Blower Manifolds with an adapter plate for the Eaton SC right?
Im using the M90 version. :D :D :D
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
