It is currently Sun Nov 08, 2026 12:27 am
 Post subject: Correct spark plug gap
PostPosted: Sun Mar 28, 2010 4:19 pm
I have a slant six motor and the workshop manual specifies spark plug gap to be set .033 to .037 thou.
I have added Pertronix 1 electronic ignition (and very happy with the result) and have heard that I should gap the plugs to say .040 thou as a stronger and bigger spark is produced with electronic ignition.
I would appreciate your views on whether I should increase the spark plug gap if electronic ignition is fitted.
Thanks
PostPosted: Sun Mar 28, 2010 5:02 pm
6 Pack Dart
With HEI's all seem to like 0.040--0.45
PostPosted: Sun Mar 28, 2010 5:12 pm
With my HEI at first i just had the gap set at .035'' then rememberd to widen the gap. Then I took it to .050'' and it seemed to run ''better''.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sun Mar 28, 2010 7:38 pm
I'm running .045 with a pertronix I and spiral core ignition wires......
Also they're extended tip spark plugs.
PostPosted: Sun Mar 28, 2010 8:38 pm
I have run .045 for years with both stock mopar and HEI ignitions.
PostPosted: Sun Mar 28, 2010 11:59 pm
crickhollow, I ran my plugs at 0.042" when I had Pertronix on it's own. Just have a play around with gaps, open them up till you start to notice changes, good or bad. You'll find what your engine likes.
Have you installed a higher output coil, or are you still using the stock coil?
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
PostPosted: Mon Mar 29, 2010 12:58 am
I am using the standard coil - I have connected the red wire from the Pertronix 1 unit to the ignition side of the ballast resister and the black wire from the Pertronix 1 unit to the (-) negative terminal on the coil.
Peter
PostPosted: Wed Mar 31, 2010 3:34 pm
I run .045 as well, either with the MSD Blaster 2 coil or the 3 ohm Pertronix HV HEI style 60,000 volt coil. The plug color is white with the HV coil. Cream/light biege with the Blaster 2. Still using the Orange ECU for now.
