It is currently Wed Dec 31, 2025 4:32 pm
 Post subject: 2-barrel swap questions.
PostPosted: Sun Mar 28, 2010 6:33 pm
I was wondering if I would be able to use my 1-barrel throttle cable when I swap over to a 2-barrel. Is it long enough? I know I'll need to fab a new throttle bracket. Also, on a stock 2-barrel manifold with a Carter, which direction of rotation does the throttle move when you step on the gas? Standing on the driver's side of the car facing the passenger side, does the throttle rotate clockwise or counter-clockwise? Which side is the throttle on, passenger or driver.
Thanks in advance for the help.
PostPosted: Sun Mar 28, 2010 7:43 pm
It's too long.
Yes, clockwise.
Driver.
PostPosted: Sun Mar 28, 2010 7:53 pm
It's too long.
Crap... I take it that means that there is no way of working around that without putting the throttle cable in a bind? I guess I'll start looking for an early V-8 cable or super six cable.
Once again... crap... one more thing to spend money on...
 Post subject: Over the counter...
PostPosted: Sun Mar 28, 2010 8:58 pm
You car should use the round cable end...which ended after the 1974 model year... I've used a 1974 cable for a 318(can still get over the counter at a Mopar Dealer)...or there is a Pioneer Cable available that works as well (Dan might remember the number)...
An actual Super Six cabel has the square plastic end at the firewall and will require either use of a uni-bit and drill to make things right, or and adapter...
I suggest #1 above, also do a search for the "beyond the supersix" article there should be some pics of the poor '74 I had...
-d.idiot
PostPosted: Sun Mar 28, 2010 9:45 pm
2bbl cable w/round end is ATP #Y-156 ($16 at RockAuto.com).
PostPosted: Mon Mar 29, 2010 2:46 am
I never changed the throttle cable on my 70 Valiant I just looped it around and held it like that with a wire tie.
PostPosted: Mon Mar 29, 2010 2:55 am
That was my immediate thought but I wasn't sure if that would work. I figured it could possibley put the cable in a bind.
 Post subject: Re: Over the counter...
PostPosted: Mon Mar 29, 2010 2:57 am
-d.idiot
Well thanks for the head up. I wouldn't have been to happy if I found that out the hard way. Good to know these cables are reproduced, that eliminates the primary headache or finding it.
PostPosted: Mon Mar 29, 2010 3:00 am
Cool, thanks Dan. $16 isn't too bad, I just wonder how much that comes up to after shipping, shouldn't be more thatn $30.
Sometimes I swear I could tell someone that $5 is alot of money :lol: (it is :shock: )
PostPosted: Mon Mar 29, 2010 6:57 am
Well, yeah, if you need $5 and you don't have $5, then it might as well be $5,000,000. Kinda like how long a minute is depends on which side of the bathroom door you're on. :shock:
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 8 guests
