It is currently Mon Nov 23, 2026 6:16 pm
PostPosted: Mon Jun 30, 2003 9:21 pm
:roll:
I'm still rolling on the H-pak stuff, just trying to get couple of candidates for carb 'tuning'. Anyhow, I'm trying to get the bowls off of two of my 4 Holley carbs, these have sat for a year or more, so I want to rebuild one or two, and also take notes on the jet size, power valve, and what my pump shot's gonna look like...
Two of my carbs I can't get the bowls off of...the screws are out, I've heard Holley used on some models a 'composition gakset with sealant'...
I've tryed to use a screwdriver with firm pressure, but don't want to crack the bowl, or damage anything. Any tricks on getting these to budge???
thanks,
PostPosted: Mon Jun 30, 2003 10:40 pm
Hmmm, I've always just given stubbern bowls a few wacks with a screw driver handle. Seems to work for me anyway... :shock:
PostPosted: Mon Jun 30, 2003 11:38 pm
Well, if you are going to rplace all the internals anyway you may want to just try dropping the whole shebang into a dipping tank overnight and let the cleaner soften up the gaskets. Or maybe soak the gaskets with some gas to try and lose it up. Or use this as an excuse to buy a Edelbrock or an AFB (its what the hyper-pak came with originally anyway ;) )
Reed
 Post subject: Not going there...
PostPosted: Mon Jun 30, 2003 11:50 pm
I'll stick 'em in my tank o' Berryman's I guess. I was hoping not to destroy the pump diaphragm and a bunch o other parts that way, but...
I have the Carter manual, and the Holley manual... I'd rather go with the Holley on the H-pak, especially since I have to tune for a short bump stick long ram, big plenum...the carter just isn't gonna give me the flexability to change the pump shot, and hork with the jets ( I notice from previous posts, dschumers is running 4 different numbered jets in his carb on a shorty manifold...).
Probably going to have to get a 'trick kit' too so I can keep changing stuff and gaskets after reading the plugs....
Jeez... this'll be fun...
:roll:
Thanks....
PostPosted: Tue Jul 01, 2003 6:31 am
You might just try a thin blade, like a utility knife to run along the seam and slice through the gasket for a little way, then it should open up like a clam shell.
Jerry
PostPosted: Tue Jul 01, 2003 8:56 am
When I reinstall a Holley fuel bowl, I use chap stick, vaseline or grease on the gasket to help keep it from sticking the next time I need to change jets.
Cecil
PostPosted: Tue Jul 01, 2003 9:07 am
You can apply solvent right to the gasket area to help soften them up.
Anything with a little oil in it like WD40 or Liquid Wrench so it does not quickly evaporate away. Soak it for a while then go at it.
PostPosted: Wed Jul 02, 2003 12:12 pm
Just whack the damn thing with a screwdriver handle like someone said above.
 Post subject: They're apart....
PostPosted: Wed Jul 02, 2003 12:18 pm
Got them apart last night, it took a half a can of gasket remover to soften some of them up, three of them used the composite gasket which is like cardboard with tar on two sides....I had to use a wood chisel and small plastic mallet and litely tap and pry things apart...what a mess....
Now, I have two more to autopsy and see if I can get one set up for a 'baseline'... would be nice to get it all setup before the mopar meet on the 19th...if not, it'll give me time to tech 'n' tune for drag season next year... :D
