It is currently Fri Jan 02, 2026 2:32 am
 Post subject: replacing timing chain
PostPosted: Mon Mar 29, 2010 1:47 pm
I'm about to replace the timing chain, gears and cover.
a couple of questions:
1) should I also replace the oil seal?
2) how do I remove the crankshaft gear?
Any help would be appreciated.
Thanks
Dan
PostPosted: Mon Mar 29, 2010 2:13 pm
Yes on the oil seal,nows the time while you can get at it.
A gear puller,two or three leg which ever you have that has the depth.Good luck
PostPosted: Mon Mar 29, 2010 2:47 pm
....and get a sleeve kit for your damper if there any groves in it. If not the new seal won't seal at all.......
PostPosted: Mon Mar 29, 2010 3:04 pm
When I did mine I HAD to use a 3 jaw puller with a cage around the jaws to keep it on the gear.
good luck
85 d-100 HEI 2BBl
06 Toyota Corrola
