It is currently Fri Aug 28, 2026 4:30 pm
 Post subject: Duster on the blocks
PostPosted: Mon Jun 30, 2003 10:07 pm
Well,
Here's where the '76 Duster parts car finally ended up. I had a pile of blocks lying around, so we jacked it up in the air to make it easier to get underneath to work.
First order of business is to remove the front end and rebuild it before the transplant into the '74 Sport. Then we'll tackle the rear end for the LBP axles.
Will keep ya posted,
Jerry
 Post subject: Don't crawl under there!
PostPosted: Tue Jul 01, 2003 10:03 am
Jerry, we need to preserve our cars and ourselves . . . your concrete support blocks make me shudder :shock: . . . too many horror stories of these things crumbling without warning. In the archived section there was an entire thread about guys on this board who had close calls with cinder blocks. If you were a Ford guy, no big deal :wink: but your a slant guy . . . get some reliable supports under there!
Cheers!
Al T
PostPosted: Mon Jul 07, 2003 8:45 am
so what r u not going to use on that machine?
PostPosted: Mon Jul 07, 2003 8:46 am
