It is currently Tue May 12, 2026 12:54 am
PostPosted: Mon Mar 29, 2010 3:18 pm
ok i have a 7.25 that i've been looking for a posi for, for a while and i dont have to money to get a bigger rear and have already put money in rebuilding the 7 with 3.55 gears. i was wondering if any one have heard of or thought of a way to convert open to posi with out welding spyders together, i'm looking to remove the spyders and some home pin or do something.
anybody????
 Post subject: spool
PostPosted: Tue Mar 30, 2010 2:39 pm
Now this is old school, VERY old school,like front engine dragster old. I have never done it but guys shimmed the spyders till they locked tight on 8 3/4 open rears for a home made spool, locker, what ever you want to call it. I am sure it takes alot of trial and error. I am not sure how long it lasts or if I had the guts to try it.
PostPosted: Tue Mar 30, 2010 3:11 pm
It is not hard to do...
Just doube-up the shims that go behind the side & spider gears.
For even more "drag" on the spider gear assembly, you can install a motor cycle valve spring in-between the two spider gear faces, then push the cross-shaft thru the spring to hold it in place.
If done "right" :roll: :wink: the spider / side gear will be locked solid when the unit on the bench but you will hardly feel the added friction in operation.
A tightly shimmed open diff will spin both wheels in a straight line and on wet surfaces. It will not do drifter type slides or doughnuts.
I find that doing this mod turns the gear oil black faster and in the case of a 7 1/4, will break weak spider gears.
PostPosted: Tue Mar 30, 2010 3:29 pm
do if i'm going to try to shim the spyders tighter i should start stocking up on spyder gears for when they break?? by doing this will i get enough of a posi ish rear to when running slicks at the strip i will hook hard.
PostPosted: Tue Mar 30, 2010 3:39 pm
A "hard hook" and a open carrier 7 1/4 don't "mix".
Save yourself some trouble and find a stronger rear axle assembly to work with.
PostPosted: Tue Mar 30, 2010 4:00 pm
yeah i know i'm working on tring to get a 8 1/4 or 8 3/4 but dont have the $$ right now. i already rebuilt the 7 with 3.55s and did new brakes and all that stuff. really want to find a 7 1/4 sure grip, bought one years ago but it was completly distroyed.
 Post subject: shims
PostPosted: Tue Mar 30, 2010 5:45 pm
Thanks Doc, I was hesitant on that post thinking that most would have thought I was nutz!!
PostPosted: Wed Mar 31, 2010 8:52 am
I am just as "nutz"... seeing that I tend to go "out of my way" to try a lot of those "who knows" ideas... just to end-up with broken parts... but now I know. :roll: :lol:
I will say that a tightly shimmed "open" 8 3/4 works pretty well.
I am currently running one, a tightly shimmed 3.07 ratio and it reduces the amount of one wheel "sit there & spin - no forward movement" type action.
The tight spider shimming also reduces the amount of backlash in the assembly so there is not a loud "clank" when putting the car in gear.
The big difference... the 8 3/4 open carrier and spider gears are a lot bigger and stronger then the 7 1/4 parts.
PostPosted: Wed Mar 31, 2010 3:08 pm
yeah i'm probly just going to leave mine alone cuz i know its weak, i will continue search for cheaper 8 3/4, i screwed up years ago, had the chance to get a full drum to drum brand new everthing 3.55 posi 8 3/4 at carlisle for 800 bucks.
 Post subject: 8 3/4
PostPosted: Wed Mar 31, 2010 6:22 pm
That still is the going price. Found one at MATS swap meet for $700. PM me and I can get you the guys # I think he will ship.
PostPosted: Thu Apr 01, 2010 6:29 pm
hey thanks alot but i just found a posi unit for my 7 1/4, with brand new clutchs,ring/pinion,bearing,axle bearings.
 Post subject: Shims
PostPosted: Sat Apr 03, 2010 5:04 am
So it takes just one additional shim under each gear? And where do you buy the shims? I may need to try this.
Rick
PostPosted: Sun Apr 04, 2010 9:00 am
Just weld it together to make a spool. Circle track guys have doing that since about 1930.
 Post subject: Re: Shims
PostPosted: Mon Apr 05, 2010 11:36 am
Rick
I have a lot of side gear shims if you need a couple.
