It is currently Tue Nov 24, 2026 10:42 pm
 Post subject: EFI Turbo Update
PostPosted: Tue Jul 01, 2003 6:50 pm
This past weekend I took my second 250-mile trip with the EFI turbo. This one was a real test with the temperatures well into the nineties. So far I've got close to 1K miles on the turbo and it's running great.
I've never driven a turbo car before and the thing that surprised me the most is the increase in power even under light load and before the boost goes positive. I guess I really notice it because I've driven this same car with and without a turbo. The difference is dramatic even under light load and at part throttle. This thing flies up hills!
I'm running the boost at 7 pounds until I get a BTM hooked up. Then I'm planning on going to 10 pounds.
Bob D
PostPosted: Tue Jul 01, 2003 9:22 pm
I expect a long, extensive, detailed article on the installation along the lines of your EFI article :mrgreen:
PostPosted: Tue Jul 01, 2003 10:29 pm
Thanks for the up-date Bob, sounds like things are working well.
Any "bugs" or funny problems crop-up yet?
PostPosted: Wed Jul 02, 2003 12:46 pm
Doug,
The only "bug" I have is that the engine is a little difficult to start when warm. This is because I'm still using my batch fire ECM from a naturally aspirated 3.8L engine. So, with no sensor input during start-up the ECM "thinks" that the stock non-turbo 22lb/hr injectors are still being used. This results in too much fuel from the larger 28lb/hr injectors during start-up. During cruise the MAF (from a turbo 3.8L), and the oxygen sensor, keep the mixture right on. What surprised me a bit is that at WOT this ECM, along with the turbo MAF, keep up with the fuel requirements of the turbo. At least up to 7 pounds of boost. This really demonstrates the adaptability of the MAF system!
I will eventually use a turbo ECM, but first I have to work out some timing issues to use the turbo "crank sensor" ECM with my distributor.
I get around the warm start problem by starting the car in "flood clear" mode (pedal to the floor). When cold the engine starts beautifully.
Bob D
PS. Is something wrong with the site or is it just me? Everything is extremely slow.
PostPosted: Wed Jul 02, 2003 1:30 pm
Good info. Bob.
As for the site, yes it is slow, one of the servers is down, Chuck is on it but it may take a few more days to get fixed.
PostPosted: Wed Jul 09, 2003 10:13 am
Cool beans, Bob. I may be picking your brain about parts and such in the near future. The itch for boost is getting unbearable over here!
Cheers,
PostPosted: Wed Jul 09, 2003 8:01 pm
Lou,
Your g-machine with EFI and boost would be the coolest beans!
Bob D
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
