It is currently Fri May 08, 2026 11:19 am
PostPosted: Sun Apr 04, 2010 4:07 pm
Alright, I've been doing some electrical work on my Scamp.
The fuel and coolant temperature gauge do not work.
I took apart the dash, it already has a regulator built into the back of the gauge cluster, what else could be causing my gauges not to work?
Also, the car cranks over occasionally and then I hear a clicking, rattling sound and I have to mess with the automatic column shifter to get it to start, moving the lever between P and N until it clicks the "right way" and starts.
I know the noise is coming from a relay, I included a picture on top. I have no clue what it is, it has the numbers 3588587 and 36033 on it.
Any help would be much appreciated, thanks guys!
1967 Barracuda Notch - Autocross 440 project
2000 Subaru Forester
PostPosted: Sun Apr 04, 2010 4:15 pm
The regulator is probably faulty, if both of those gauges don't work. Replace it. Use this one if you're smart.
Your Neutral Safety Switch is faulty. It's a combination Neutral Safety/Reverse lamp switch screwed into the transmission. Replace it.
PostPosted: Sun Apr 04, 2010 4:22 pm
Thanks Dan, I guess that explains why my reverse lights don't work either. Pretty spendy regulator, hopefully it's worth it.
Thanks so much!
PS: Do you know what this box (relay) is? I went through a bunch of threads, seems like no one could agree what it was.
I know my vehicle didn't have a seatbelt interlock box (I looked everywhere!) but I did find seatbelt safety warning light, sensors under the bench, a buzzer, etc.
Thanks again!
PostPosted: Sun Apr 04, 2010 5:13 pm
It looks like your horn relay.
Right, that was only on '74 models.
PostPosted: Mon Apr 05, 2010 1:59 pm
Ordered that limiter, damn it was a bit pricy, but it's american made and solid state so it should be worth it at $62 shipped. Due in on Friday.
I also got a neutral safety switch from Napa. You where right, tested the switch and it was bad. So glad I had a 1" crow's foot, or else getting it out next to the exhaust would have been hard! I'll keep you posted, thank you!
PostPosted: Fri Apr 09, 2010 1:56 pm
I got the limiter, nice little piece!
Seems like a quality company.... :D
I installed it, my gauges still won't work. Any troubleshooting suggestions? Thanks you!
PostPosted: Fri Apr 09, 2010 2:03 pm
Gauges themselves could be toast if the old limiter stuck closed and sent 12v to 'em. Instrument cluster ground could be faulty (or missing -- if you are checking for function with the cluster out of the car, that won't work; you would need to connect a temporary ground wire). Could be open circuits on the gauge circuit board, or a loss of feed at the main multi-pin disconnect.
PostPosted: Fri Apr 09, 2010 2:52 pm
Hopefully they aren't fried, they worked for a bit and stopped working when I first got the car. I'm sure that doesn't mean much though...
Where is the instrument cluster ground located? Thanks Dan!
PostPosted: Fri Apr 09, 2010 3:11 pm
It grounds via the mount points.
PostPosted: Fri Apr 09, 2010 6:29 pm
Well, I don't think the ground is the problem.
I read the instructions for the limiter, it says if plugged in correctly, it will flash a red led, which it does.
Do you think my gauges are fried?
Any way to test them?
Thanks again for your time!
PostPosted: Fri Apr 09, 2010 7:18 pm
Apply a regular 9v square battery to the pins on the back of the gauges. If the needle moves, the gauge is good. If not, it's fried.
PostPosted: Sat Apr 10, 2010 9:14 am
Thanks Dan, I'll have to rip the dash apart again later on and try it, if they are fried, what is a good source to restore my gauges?
PostPosted: Sat Apr 10, 2010 9:21 am
Your gauges repaired by R/T Engineering (website organisation sucks, this refers to E-bodies, but they do repair all Mopar gauges)
Or get new ones from Year One.
