It is currently Tue Nov 24, 2026 2:06 am
PostPosted: Thu Jul 03, 2003 5:53 pm
Ok
I feel pretty good now.
I got my super six conversion on and I got the car to start and run.
I have to take it to the muffler shop because I want to get a nice fat 2 1/4 inch exhaust and a flowmaster. So, I am thinking this is not the best time to try and locate an exhaust leak since the manifold outlet is pretty much wide open.
Still the part I am most concerned about with this whole job is exhaust leaks at the union between the manifolds and the heads and the intermanifold union. I dont want to have to start over again!
I let the car heat up and there was some smoke coming from an area of the manifold that is not near the head. I think this is the extra oil and junk from my greasy hands during the build up process.
During assembly I used the instructions on this site and followed them to the letter. I used the reccomended NAPA gasket and checked my manifolds for warpage vs the gasket. The exhaust wasnt perfect but it seemed within spec. I also test bolted the whole thing without a gasket and used a .01 feeler gauge to test for gaps. I am no expert but once I tightened all the fastners it all seemed nice and snug.
I bolted it up using hylomar around all of the ports on both sides and used the correct fastners for each stud. I also checked my torque specs very carefully with a good quality wrench. Just eyballing it the whole thing looks pretty good. From what I can see there are no big gaps and the manifold seems to be smashed nice and flat onto the gasket in all places that are visible.
So, when it was running today I passed my hand around the general manifold area and didnt feel anything weird but it is also hot as hades around there so I couldnt get too close. Still once heated up I didnt see any smoke coming from the end exhaust runners near cyl 1 and cyl 6. I am to understand this is the most common area for leakage.
So, I guess the short of all this drivel is: If I had a leak where the manifold meets the head is it something that would be totally obvious? Are there some signs I should be looking for?
I think things will become more evident once I make it back from the muffler shop and can begin dialing everything in.
Thanks and happy july 4th
Dr Wheelie
Dr Wheelie
Users browsing this forum: Bing [Bot] and 8 guests
