It is currently Sat Jul 18, 2026 2:32 am
 Post subject: Compression Ratio
PostPosted: Fri Apr 09, 2010 4:56 pm
My CR works out to 7.94:1 with the Wiseco pistons I had made.
Head is 58.75 cc and the pistons sit down .1675"
Perfect to boost up!
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Apr 09, 2010 5:26 pm
Yep, I'd say that's about perfect. What cam are you using?
PostPosted: Sat Apr 10, 2010 5:50 am
Tom, Did you get the Stretch Gauge to work or did you go with the TA gauge?
PostPosted: Sat Apr 10, 2010 6:39 am
I ended up adding a spring to the the stretch gauge so it can support its own weight. It looks like it should work fine now. I have not had a chance to work on the short block since Weds .
11.02 @ 120.56
Chassis dyno
PostPosted: Sat Apr 10, 2010 6:36 pm
I just torqued mine to what the card said,and went the 30 degrees????,,,,,,whatever the card said,further.Guzzi Mark
PostPosted: Sat Apr 10, 2010 6:41 pm
Thats my back up plan....but have this tool and would have to borrow the other.
11.02 @ 120.56
Chassis dyno
