It is currently Tue Nov 24, 2026 8:27 am
 Post subject: External Oil Pump
PostPosted: Fri Jul 04, 2003 1:32 pm
Since having all the problems with our oil pump gears...etc, I have been thinking about a cheap externally driven pump.
What about mounting a stock or high volume oil pump on an Aluminum plate similar to an engine plate. You could mount it on the drivers side of the engine, low, beside the water pump You could drive the pump off a crank pulley type setup and use a block off platr similar to the one in Seymours last article.
This would give some more space down on that cramped side of the engine. The oil filter would also be out in the open. Aluminum plate is pretty cheap. Hoses aren't all that expensive? The only thing I'm not sure of is the pulley to be mounted on the oil pump shaft.
What do you think? What am I missing? Or is this a big waste of time and brain cells. My understanding on the external pump setup is that for most people they are pretty pricey?
Rick
PostPosted: Fri Jul 04, 2003 1:59 pm
I wouldn't trust external belt setups with oil pressure. If your water pump belt jumps off, you run hot and have a chance to notice and shut it off. If your oil pump quits, especially with solid lifters which won't rattle when oil starved, you notice when your main/rod bearings start knocking. Not good.
PostPosted: Fri Jul 04, 2003 4:32 pm
How about electrically driven? A small DC motor should do it. If you were to use a stock, or any pump for that matter, how would you run the plumbing?
 Post subject: Oil Pump
PostPosted: Sat Jul 05, 2003 1:14 pm
My thoughts are that you could run a low oil pressure cut off switch and then the engine shuts down automatically on loss of pressure. Plus, aren't all external pumps belt driven already?
I was thinking you could plug the existing oil pick-up where it screws into the block. Install a new pick-up through the side of the pan and run a hose approx. 18-20" to the newly located oil pump. Oil flows through the pump and filter as normal and then exits via a new hose or hard line back to the existing oil pump mounting pad where an adapter would be needed.
It doesn't appear to me that this would be a real high priced proposition? My only concerns are how to mount a new pulley on the oil pump to drive it?
Rick
PostPosted: Sat Jul 05, 2003 1:39 pm
Rick, also need to consider pulley diameter and the possibility of pressure loss from such long runs of hardline or hoses. Thinking along the lines of some type of external regulator to ensure correct pressure. Don't know of any regulators specifically for this, interesting just the same. I think your'e on to someting here. You've got me curious. 8) 8) 8) 8) :lol: :lol: :lol:
 Post subject: Pressure loss
PostPosted: Sat Jul 05, 2003 3:57 pm
Of course this is all in my head,but I was thinking if there were significant pressure losses that they could be overcome by using the high volume oil pump. With the extra load this pump places on the cam gear we are not using it. But with a belt driven pump that would not be an issue.
Rick
PostPosted: Sat Jul 05, 2003 5:40 pm
Rick, Need to determine oilpump shaft rpm to crank rpm (with all accesories intact)and divide the two to arrive at pulley ratio and then translate this to a diameter. I was thinking of a test stand fitted with a electric motor with pulley/belt plus rpm and pressure gauge fitted, Hook a rehostat to control speed and you would be able to run it under simulated rpm load. Also would permit you to actually mock up lines and experiment with hose/hardline diameter and address any pressure loss issues and provide for some serious duribility testing on the bench, its a idea. What do you think? As for mounting pulley need steel shaft that is interference fit to oil pump shaft diameter with flange welded on one end to bolt on pulley. Would make this fit as tight as possible and drill for a swaged rollpin. Ultimate idea is to get both to rotate as one and avoid any extensive modifications to the pump shaft. Dave
PostPosted: Sat Jul 05, 2003 7:41 pm
Car Model: '23 T-bucket
Here's my 2 cents..........--> DIRECTION OF ROTATION! <---
Roger
 Post subject: Time for a re-think
PostPosted: Sun Jul 06, 2003 10:29 am
Rethinking the feisibility of being belt driven. motor driven would provide these advantages: could run motor off a tach signal (is this possible?) and/or provide manual control to maintain a set pressure using motor rpm, remote mounting independent of belt system and elimanate pulley. Now this begs the question where does one find a reliable 12V motor? This would be a far easier instalation. As a curiosoty I did a search. Check out www.thinkauto.com for complete electric oil pump systems and accesories
