It is currently Wed Jun 24, 2026 11:05 pm
 Post subject: Push Rods
PostPosted: Wed Apr 14, 2010 11:21 pm
:twisted: hello, to all, I'm just learning how to rebuild my 225 dodge dart, and I'am having trouble with my pushrods, I just bought a new set, and 4-5 of the rods are up, and not allowing me to screw them down, can some-one please explain. Thanks Pat
PostPosted: Wed Apr 14, 2010 11:36 pm
Uh, yeah, those pushrods that won't go all the way down are for the valves that are open while the engine is in this particular rotational position.
If you rotate the camshaft / engine, all the pushrods will move up and down in turn, as the lobes of the camshaft cause the lifters to lift, pushing the pushrods up and, if they are in place, rocking the rocker arms, which open the valves.
 Post subject: ok that helps
PostPosted: Fri Apr 16, 2010 10:19 am
Do I have to tighten them down to seven pounds as well compressing the springs or leave them? Thanks
PostPosted: Fri Apr 16, 2010 11:27 am
There is no "tighten to 7 ftlbs" spec. - where did you see that?? :?
When building an engine, I drop-in all 12 pushrods then install the rocker arm assembly. You have to get all the rocker arm shaft bolts started, then tighten them all down evenly, a couple of turns on each, until the assembly seats on the head towers. You need to check to make sure the push rod cup end stays on the rocker arm "ball stud" as you slowly tighten all the bolts.
A few of the valve springs will compress as you tighten the rocker arm shaft down.
After the assembly is installed with all the push rods in position, do the valve lash adjustment. You will need to turn the engine a few times as you check the lash settings.
 Post subject: ok
PostPosted: Fri Apr 16, 2010 3:17 pm
What and where do i deal with the lash adjustment, Thanks
PostPosted: Fri Apr 16, 2010 5:32 pm
6 Pack Dart
Please READ "Doc's" post just above yours :roll: :!:
 Post subject: ok
PostPosted: Fri Apr 16, 2010 7:03 pm
So, thats all I need to know then?
 Post subject: one more question
PostPosted: Fri Apr 16, 2010 7:14 pm
So, how do I know when it is adjusted correctly?
PostPosted: Fri Apr 16, 2010 7:27 pm
Site Admin
Nope. You need a lot more to make it run right. :wink:
Search through the FAQ's and articles. Search the board for Valve Lash, and so forth. Your going to need to find the torque spec as well.
If your new to mechanics, you might want to get somebody to help you along. Coming here is a great resource, yet having somebody that has a lot of experience makes a big difference.
See if somebody on here lives close to you, and get a hand. After you've done a few of these things, it gets a lot easier. :D
CJ
PostPosted: Fri Apr 16, 2010 7:28 pm
Site Admin
Do you have a shop manual of some sort?
CJ
 Post subject: ok
PostPosted: Fri Apr 16, 2010 11:28 pm
Thanks for all the help, I will continue to read, and try and understand how to do this. Pat
 Post subject: Good
PostPosted: Fri Apr 16, 2010 11:41 pm
I found great info from slantsix dan, thank you all for the help, and the detailed descriptions, back to work, well see what happens. :D
 Post subject: Re: ok
PostPosted: Sat Apr 17, 2010 4:55 am
the most important thing you can do is refer to a good workshop manual,preferably a factory issued one.
however,here is a line drawing to show you where the adjustment point for the valves is,and the locknut to adjust them.
if you do not have a manual,I suggest you at least borrow one,maybe from your local library, to complete your job.
mistakes can be costly.
click here
the suggestion by Ceej to have an experienced person help you is a good one that you should try and make happen.
regards,Rod
:D PS: where are you located?
 Post subject: now
PostPosted: Sun Apr 18, 2010 6:31 pm
Well, I tried to fire it up today, and a flame came through the carb, but it just wouldn't start, now I'am back to troubleshooting, but yea I live in Beaverton, Oregon. Thanks
PostPosted: Mon Apr 19, 2010 7:27 pm
Hows your cam/distributor timing?
85 d-100 HEI 2BBl
06 Toyota Corrola
Users browsing this forum: Amazon [Bot] and 9 guests
